17" or 16" ?
Your front offsets are too low to run dropped and your rear wheels (and offsets) are too narrow to run anything close to a 255. 7" is just too narrow a rear wheel for this car. Also running 215/40/17 and 255/40/17 is a bad idea due to the difference in O.D. between front and rear.
Sorry.
PS Have you even tried reading the sticky at the top of the wheel and tire forums?
Sorry.
I would not recommend 35 series tires on 17s. That will look kinda silly, possibly freak out your ABS system, and more than likely not prevent your rubbing issues. The width of the tires, combined with offset of the wheels, has more to do with rubbing than anything else.
I honestly would suggest new wheels. A truly staggered wheel setup will benefit you more overall, and make it easier to find the right sized tires. I wouldn't dare suggest a tire as wide as 255mm on a 7" wheel.
thanks for your input both of you guys.
haha mike, dont feel bad (you said sorry).
i purchased the car with this setup. therefore, finding out whats needs to be changed about it doesnt hurt my feelings at all. i want to make my car better
i actually have browsed though the sticky at the top, but maybe not thoroughly enough. but thanks so far guys.
