17" SSR Comps
Old Mar 25, 2004 | 05:26 PM
AA2000's Avatar
Default 17" SSR Comps
Hello all. I just got my 02 S and was looking at the SSR comps...though I can't find answers to my questions doing the search feature...so here are my Q's...
What are the offsets for the 17's?
8" fronts and 9" rears...do I go with 215F and 245R or 225F and 255R? I've seen some with the 225/255 setup but isn't that a little bit too thick for 17s?
Is anyone with 17" Comps running with 215/245? Any pics?
BTW, I don't plan on lowering my car...but would like to start autocrossing with it.
Thanks for the help.
Old Mar 25, 2004 | 05:38 PM
Axel6's Avatar
I got Kumho V700, 225/45-17 fronts & 255/40-17 rears. I have yet to receive the tires/wheels. I will update you when I do. I have a feeling that this will be a very competitive combination.
Old Mar 26, 2004 | 08:01 AM
gaebril's Avatar
Believe the offsets are +48 front and +55 back.
Old Mar 26, 2004 | 01:28 PM
Fongu's Avatar
[QUOTE]Originally posted by AA2000
Old Mar 26, 2004 | 01:54 PM
AA2000's Avatar
Thanks for the reply and info!!
Old Mar 29, 2004 | 08:38 AM
Axel6's Avatar
[QUOTE]Originally posted by Fongu
Old Mar 29, 2004 | 08:38 PM
Project SSAP1's Avatar
i really want the SSR comps too in 17...after doing some research i found that the 17x8 is +47 and the 18x9 is +55...its not that bad...but if u lowered a lot u might have some fender rub...time to roll those fenders homie 2 b on the safe side
in result i once again leading towards the ce28n in 17...
Old Mar 29, 2004 | 08:44 PM
AA2000's Avatar
18x9? You mean 17x9?
just curious, what made you lean towards the CE28N instead of SSR Comps?
Old Mar 30, 2004 | 08:30 AM
Fongu's Avatar
IMHO the Tirerack SSR's have marginal offsets, while the Volk CE28N's have good ones. The standard size SSR-type C sizes on the Speedstar web site have acceptable offsets too, but smaller width rims.
Here are some numbers for you to decide for yourself:
'00 to '03 OEM: Front (16"x6.5", +55mm) Rear (16"x7.5", +65mm)
CE28N: Front (17"x7.5", +50mm) Rear (17"x9", +63mm)
Tirerack SSR Comp: Front (17"x8", +48mm) Rear (17"x9", +55mm)
Standard size SSR Comp: Front (17"x7.5", +48mm) Rear (17"x8.5", +55mm)
I ran out and measured the top of the OEM rim lip to the OUTSIDE of the fender and got 25mm on the front and 35mm on the back. If you do the calculations the Tirerack SSR rim lip goes right to the outside of the front fender and has 6mm space in the back. The Volks have 7mm front and 14mm behind. The tires are going to be wider than the rims, so you can see what's going to happen. DISCLAIMER, I didn't move the suspension up and down to check the camber curves, etc. to see if it will really fit.
I really want the Tirerack width SSR's, and they are a great price, but for the life of me I don't understand why they got such a low custom offset.
Old Mar 30, 2004 | 02:11 PM
AA2000's Avatar
They're a great price. From your data, it seems that Tirerack's SSR Comps' offsets are too low for the wheel width. I see the problem with that, especially with aesthetics and fitment alone.
MyHieu
May 26, 2004 12:38 PM
M-Type
Dec 19, 2003 02:44 PM
Jason00S2000
May 1, 2003 02:04 PM
wdskuk
Oct 18, 2002 11:09 PM
shingles
May 12, 2002 10:58 AM
