17's in the front
Old Jul 19, 2007 | 09:50 AM
eraxpres's Avatar
theres people here that run NSX wheels...which are 17's in the rear and 16's in the front
Old Jul 19, 2007 | 05:06 PM
sd-imports's Avatar
just make sure the diameter of the wheels are similar or you adjust your suspension ride height to compensate . You don't want to throw off your center of mass or you will change the handling.
Old Jul 19, 2007 | 08:36 PM
han racer's Avatar
^that redhead is hypnotic I was staring at that thing for so long
Old Jul 20, 2007 | 08:51 AM
sd-imports's Avatar
my cyber girl friend
Old Jul 20, 2007 | 11:33 AM
PJCC's Avatar
There should not be any problem if you run the propper sidewall height. Example:
If stock fronts are 215/45R16, get 215/40R17.
If stock rears are 245/40R16, maybe a 245/30R18 will have the same overall diameter.
Now, finding a matching 17/18 inch rim set with the right offsets And width, that's a challenge.
Old Jul 20, 2007 | 03:55 PM
Hoa's Avatar
Hoa
wider tires is always better. i would go for the widest tires i could get. i would recommend
Front: 245/40/17
Rear: 275/35/18 (require high offset)
if you get +73 offset for the rear, you can fit 285/35/18 tires
rsxiness03
Apr 17, 2012 07:29 AM
ayellows2k
Mar 30, 2012 02:30 PM
B serious
Apr 15, 2010 10:49 AM
plasticfish
May 17, 2006 03:24 PM
IcebergS2000
May 12, 2006 09:10 AM
