17x10, 275/40
Old Oct 16, 2012 | 04:05 AM
rmk232's Avatar
Default 17x10, 275/40
I'm doing a rear over fender on my car. Going to be running 17x9 +45 up front with a 255/40. Not worried about that I know it works. In the rear I am going to be running a 17x10 +18 which will fit just fine with the flares I am doing. HOWEVER, I don't know if a 275/40 Is going to be too wide on the wheel. Someone help me out here.
Old Oct 16, 2012 | 07:17 AM
Jin_SK's Avatar
I've got 275 NT05s on my 10's, you're good to go wheel/tire wise. Hope the over fenders are going to be pretty wide, my setup is +70.
Old Oct 16, 2012 | 07:27 AM
Squirtle's Avatar
Not gonna fit without either looking stupid, or stretching the tire.
Old Oct 16, 2012 | 07:49 AM
Bullwings's Avatar
Originally Posted by Squirtle
Not gonna fit without either looking stupid, or.... looking really stupid.
There, fixed it for you...
To the OP, even with over fenders, unless you're running something like the Amuse widebody kit, you still need to keep it below +35 if you want to run that kind of rubber. GL, but I don't think that is going to work.
Old Oct 16, 2012 | 08:01 AM
rmk232's Avatar
Thank you for answering my question.
Why would I want to stretch tire? To be slammed and defeat the purpose of my car? No thanks.
Please review what I posted. I did not specify a flare because I fabricating custom ones. I was simply asking for tire sizing on my wheels. Please take you snare remarks back to VWVortex,
Old Oct 16, 2012 | 08:20 AM
Manga_Spawn's Avatar
Site Moderator
So for a 275 you could do either a 40 series tire (110 side wall height) or a 35 series tire (96 side wall height). Either way the side wall will be a little taller than the comparative 255/40 or alittle shorter. I don't think either would be enough to negatively impact performance but the 35 might give you alittle more space if you need it. Also I am not sure which size has more tire options available.
Old Oct 16, 2012 | 01:28 PM
Bullwings's Avatar
Please review what you posted... LOL. You FIRST said, rear over fender (so i was thinking ASM). Then later You said flares with no mention of custom... so, which is it? You can't flare over fenders since they're made of FRP or CF...
Don't know why i'm still trying to help, but here's a rim/tire size calculator
http://www.1010tires.com/tiresizecalculator.asp
Old Oct 16, 2012 | 01:39 PM
S2k007's Avatar
If you're simply asking if 275 is too wide for a 10 inch wheel, the answer is no. It's the correct size. Although you really could fit any where between 255 to 285 on it.
Old Oct 16, 2012 | 09:21 PM
rmk232's Avatar
Originally Posted by rmk232' timestamp='1350403266' post='22086119
[quote name='Jin_SK' timestamp='1350400658' post='22085976']
[/quote]
You're not helping. And yes custom made flares, rivet on custom over flares. Would you also like to know my height a weight? Maybe that will satisfy you.
Old Oct 16, 2012 | 09:38 PM
Bullwings's Avatar
Originally Posted by Bullwings' timestamp='1350422936' post='22087220
[quote name='rmk232' timestamp='1350403266' post='22086119']
[/quote]
[/quote]
Try using actually using it before trash talking. this is what my search turned up...
Stock Tire - 275/40R17 Search Tires
Section Width: 10.82 in 275 mm
Rim Diameter: 17 in 431.8 mm
Rim Width Range: 9 - 11 in
Overall Diameter: 25.66 in 651.76 mm
Sidewall Height: 4.33 in 109.98 mm
Radius: 12.83 in 325.88 mm
Circumference: 80.61 in 2047.4 mm
Revs per Mile: 810.6
Tire Models Available by Size:
BFGoodrich g-Force Sport COMP-2
BFGoodrich g-Force Super Sport A/S
BFGoodrich g-Force T/A KDW NT
Bridgestone Potenza RE760 Sport
Continental ExtremeContact DW
Continental ExtremeContact DWS
Cooper ZEON RS3-A
Cooper ZEON RS3-S
Falken AZENIS RT-615K
Falken FK-452
Firestone Firehawk Wide Oval Indy 500
Hankook Ventus V4 ES H105
Kumho Ecsta ASX (KU21)
Kumho Ecsta SPT (KU31)
Kumho Ecsta XS (KU36)
Michelin Pilot Sport A/S Plus
Nexen N3000
Nexen N7000
Nitto NT01
Nitto NT05
Nitto NT05R
Nitto NT555
Nitto NT555R
Nitto NT555RII
Pirelli P-Zero Nero M&S
Toyo Proxes R888
Toyo Proxes RA-1
Toyo Proxes TQ
Yokohama S.Drive
