17x7 all around...any problems w/that?
Old Apr 16, 2007 | 09:26 PM
slanguage's Avatar
Default 17x7 all around...any problems w/that?
I might be trading my AP1 stockies for a set of 17x7 wheels all around. is that ok to run on this car, as I know the car comes with a staggered setup? The guy Im getting it from doesnt know the offset, but he thinks it might be 45. He got the car from a dealer, it is a MY01.
Also what tire size should i run on these?
Old Apr 16, 2007 | 09:42 PM
afwfjustin's Avatar
You shouldn't go with a non-staggered setup unless it's for a reason. If the reason is that you just want wheels for cheap, you're doing it for the wrong reason. You're going to induce more oversteer with this setup unless you compensate by changing tires sizes.
Old Apr 16, 2007 | 10:33 PM
SimpleMan's Avatar
Problem with a 7 inch width is you can't run wider than a 235/40 in back. But if you want to do it you could have a 205/45 in front and it would be similar to stock.
Old Apr 17, 2007 | 09:12 AM
neveronlines2k's Avatar
I ran 17 x 7.5 with 215's all the way around (just for a car show) and the handling was horrible (unless you like drifting ) the rear of the car would come out very easy compared to stock and I would not recomend running that set up for a very long period of time (I would imagine rain/poor weather being very scary on that set up).
If you up size the tires (like SimpleMan suggested) you can minimize the problem, but I would suggest going with a staggered set up unless it was a larger than the stock rear non-staggered set up (17 x 8.5 or 17 x 9's)
Old Apr 17, 2007 | 12:24 PM
slanguage's Avatar
Thanks for the input. The deal for these wheels didn't go through, so I am going to lock the thread. Thanks guys
GuardianDevil
May 29, 2010 07:03 AM
s2k_4life
Oct 11, 2008 02:12 PM
ego
Mar 16, 2008 07:09 AM
s2kspa02
Dec 10, 2006 08:13 AM
efthimios
Dec 22, 2003 07:19 AM
