Is a 17x8 +29 too crazy for the front
Old Apr 23, 2010 | 07:31 PM
Suzuka_Joe's Avatar
Default Is a 17x8 +29 too crazy for the front
I want a set of blitz type 01's cx and I found a set 17x8 +29 and 17x9 +38
the rears wouldn't be hard to fit but idk about the fronts. Is it too crazy if I just rolled my fenders and ran a bunch of camber?
Do it and look awesome or wait on another set to come along??
Old Apr 24, 2010 | 12:07 PM
s2k dre's Avatar
The fronts will fit with just a roll! No pull with 215/45 and -2 degrees. I have 17x8 +35 with those specs.
Old Apr 24, 2010 | 05:04 PM
Suzuka_Joe's Avatar
Bump. Info needed
Old Apr 24, 2010 | 05:13 PM
s2k dre's Avatar
What else do u need to know?
Old Apr 24, 2010 | 05:57 PM
Suzuka_Joe's Avatar
Your running a 6mm higher offset. I'm curious if anyone has a similar offset to a +29. That's a big difference
Old Apr 24, 2010 | 07:36 PM
s2k dre's Avatar
Not much at all. 10mm+ would be, but not 6mm.
Old Apr 24, 2010 | 10:54 PM
Mar48's Avatar
btw that equates to a 17x9 +41 in the front, so check around for someone with a 17x9 +40 in front and they should be able to help you
Old Apr 25, 2010 | 04:06 AM
ZDan's Avatar
9" wide +41 would put the outside lip of the *wheel* at the same place, but a same size tire would be stretched more and give greater clearance. Better to go by same offset and tire width, IMO.
Old Apr 25, 2010 | 04:09 AM
ZDan's Avatar
If you're just about rubbing now, 6mm less offset is too much.
Old Apr 25, 2010 | 05:54 AM
shoes59's Avatar
They're the wrong offset unless you want ill fitting wheels that look rediculous.
