17x8 +48 all around
Old Feb 20, 2011 | 02:06 PM
Brian Si's Avatar
Default 17x8 +48 all around
I plan on riding at stock height for awhile, but eventually will do a 1 or 2 inch drop. So my question is what will need to be done to make this fit and what would be the best tire size
Old Feb 20, 2011 | 07:29 PM
LowFlyin''s Avatar
If you are the stock height?
Bolt them on and get an alignment.
225/45-17 would keep your stock 25" tire and will give the tire a little stretch.
245/40-17 would be a good square size for the 8" wheel, but it will be a little shorter, will make your wheel gap a little bigger, ~3/16".
Old Feb 20, 2011 | 08:40 PM
1nate7's Avatar
Stock AP2 sizes, 215/45 front and 245/40 rear.
Old Feb 20, 2011 | 10:25 PM
Mar48's Avatar
225 is not stretched on an 8"... it's actually the exact recommended size.
17x8 +48 will be fine all around, if you do a 2 inch drop you may rub a tiny bit on large bumps but I doubt even that would happen. Worst case scenario get a more aggressive alignment.
Old Feb 21, 2011 | 04:24 AM
Jim@tirerack's Avatar
Former Sponsor
A little negative camber and you should be fine. If I can help with the package let me know.
ofsalesmen
Jun 22, 2015 12:54 PM
hondavet
19
Mar 15, 2013 10:06 AM
Metalsiren
Apr 18, 2007 07:12 AM
22calbr
Nov 8, 2006 03:46 PM
papa5murf
May 20, 2005 11:37 PM
