17x9 22offset modifications?
Old Jan 26, 2009 | 04:53 PM
  #21
nichigo's Avatar
Originally Posted by SortaRican' date='Jan 26 2009, 05:51 PM
Seeing that makes me want to keep my tsw's and rock the Ef out! How much width is gained per side with the adition of the overfenders. What sizes and offsets are you running?
Specs say you gain +25mm on each side...but i think it's closer to +20. And even then, to gain maximum clearance, you have to trim the inner lip of the over fender.
The rear spec for those wheels is 17x9 +22 and i'm running 255/40/17 RE01-R's.
Old Jan 26, 2009 | 04:54 PM
  #22
nichigo's Avatar
Originally Posted by Antonov' date='Jan 26 2009, 05:53 PM
was going say.... yeah lower looks better for sure
Fo sho...i'm just too scared to run that low. I already scrape my exhaust on little speed bumps at my current height
Old Jan 26, 2009 | 05:00 PM
  #23
Antonov's Avatar
I'm not low either. Feel so out of place here
Old Jan 26, 2009 | 05:30 PM
  #24
SortaRican's Avatar
[quote name='nichigo' date='Jan 26 2009, 08:53 PM'] Specs say you gain +25mm on each side...but i think it's closer to +20.
Old Jan 26, 2009 | 07:48 PM
  #25
nichigo's Avatar
Originally Posted by SortaRican' date='Jan 26 2009, 06:30 PM
Damn, it may not work for me then. I have 18X9.5 et 20 rears They extend out 1.75" from the fender. If I were a baller I'd get an Amuse GT1 kit and call it a day.
Are you running wide fronts as well?
Yes, I'm currently running the ASM wide front fenders which add 25mm to each side.
You can run your wheels with rear overs...you'll just have to pile on the camber and run a little stretch tire.
s2k_preme
Feb 18, 2015 06:03 PM
apr_s2k
May 2, 2012 02:22 PM
David_T
Feb 13, 2009 06:35 PM
oranje
Dec 17, 2008 05:01 PM
wazzurp
Dec 22, 2007 08:34 AM
