17x9 +40 - Can I run ...
Old Mar 14, 2016 | 08:53 AM
iDomN8U's Avatar
Default 17x9 +40 - Can I run ...
Rolled fenders and liner cut in the front. Can I run 17x9 + 40 with 255/40/17 tires without having to dip to -3.5 degrees in the front?
What's needed?
Old Mar 14, 2016 | 10:18 AM
RedCelica's Avatar
how low?
Old Mar 14, 2016 | 10:22 AM
s2000Junky's Avatar
Going to need a major front fender pull/flare.
Old Mar 14, 2016 | 11:42 AM
iDomN8U's Avatar
Originally Posted by RedCelica
how low?
KW3 at the bottom part of the recommended ride height.. about 1/2-1 finger gap
Old Mar 14, 2016 | 11:46 AM
iDomN8U's Avatar
K Thanks... I'm reading people run Nt03+M 18x9.5 +40 concave with 225 on rolled fenders, figured a 9" at same +40 would be doable without major fender work on 255.
Tires are the highest point, so I guess have the most effect on fitment.
Old Mar 14, 2016 | 12:30 PM
RedCelica's Avatar
Im with junky. Lowered as much as you are, you'll need a flare in the front with that offset and a 255 tire...and still need -2.5 camber or more, which will require aftermarket ball joints. I'd look at something in the +45 range if I were you. Otherwise, only thing you'll be DomN8'ing is going to be a parking spot at your local car meet.
Old Mar 14, 2016 | 05:07 PM
afzan's Avatar
No
Old Mar 14, 2016 | 06:48 PM
iDomN8U's Avatar
Old Mar 14, 2016 | 09:19 PM
riceball777's Avatar
I run 17x9+45 with a 255/40 on the front and it's very very aggressive. I already cracked my stock rolled fenders. Another 5mm more would be so much worst. I don't see your setup fitting properly on stock rolled fenders.
http://speed.academy/wheel-tire-offs...fitment-guide/
These guys tried to put a 17x9+40 255/40 on and they failed so bad. There even made a video on YouTube. They had to murder and pull the fenders like crazy for the front to fit. They ended up geting downforce +30 fenders.
The Internet and stance/show guys will tell you that anything fits. But functually from a performance/track perspective many times they do not fit.
Old Mar 15, 2016 | 11:02 AM
EvasiveMotorsports's Avatar
Former Sponsor
will definitely need pull and around -2.5 -3 degree camber.
