17x9 +43 with 245 in front
Old Jun 17, 2008 | 12:37 AM
Jrz's Avatar
Jrz
Default 17x9 +43 with 245 in front
Just want to run this setup with you pros here before I pull the trigger and order them. The rim sizes are-
17x9 +43 front
18x10 +54 rear
From the tire diameter calculator, I could put my new spare stock rear tires on the front
and order some 285/30/18 for the rear and come out just like stock.
What do you guys think of fitment? I'm a little worried about the front. The rear seems doable since I'm at about -2.5 neg camber. Of course I'm ready to roll the fenders and relocate the rear bumper bolt. Any suggestions would be greatly appreciated. TIA
Old Jun 17, 2008 | 01:34 AM
spitvenom's Avatar
hmm I dont think its doable without looking like gargabe bro.
id do a 225 on the front and a 255 on the rear.
Old Jun 18, 2008 | 08:33 AM
Jrz's Avatar
Jrz
thanks Spit. Just want to use the two new tires I already have. I'll just testfit the rims first before I order any tires to see how it sits. Love your new setup btw.
Old Jun 18, 2008 | 09:15 AM
Redliner16's Avatar
i think you could pull it off...
eternalLx put 17x9 +50 with 255 all around:
I believe he is, or will be running camber all around and with a fender roll in front you potentially could be fine with minor rubbing..
check out his thread:
https://www.s2ki.com/forums/index.ph...ic=581615&st=0
Old Jun 18, 2008 | 09:57 AM
Jim@tirerack's Avatar
Former Sponsor
You will have to do some modification to make the wheels and tires fit. Front and rear is going tro be tight. I would think fender well modification would be needed.
Old Jun 18, 2008 | 10:03 AM
Antonov's Avatar
you need a slight flare in the front, check the link in my sig for pics of 17x9+40 with proper size rubber for an idea how it looks and how much you need to flare.
Old Jun 18, 2008 | 11:35 PM
Jrz's Avatar
Jrz
Just placed the order on the wheels and should be in a UPS truck or on the road now. Thanks for the tips and keep them coming as I would like to pull of my original plan and not wuss out and be forced to go stretched. Thanks
butdamnbrian
Mar 4, 2014 08:44 PM
Vivid_27
May 12, 2011 10:11 AM
Moddiction
24
Mar 5, 2011 02:18 PM
FilthyAp2
18
Nov 17, 2008 06:26 PM
wassapyo69
Sep 16, 2008 06:26 AM
