17x9 45+ offset question
Old Jan 28, 2015 | 10:17 PM
Voltek's Avatar
Default 17x9 45+ offset question
So i'm looking to buy a set of buddy club p1 wheels, 17x9 with a +45 offset, the car sits on stock suspension now but I'm waiting to have a set of tien s tech springs put on which will drop it about an inch and a half. After the drop what size tire would work best and would I need a fender roll or camber? It's my daily driver so I don't want too much camber but am fine with a fender roll. I was thinking something like 235/40/17 on the front and 245/40/17 on the rear or 255, not sure as of now. Just wanted to ask for some reassurance!
Old Jan 29, 2015 | 04:55 AM
deepbluejh's Avatar
You'll need a fender roll all around, plus camber (2-2.2) and a bumper tab relocation (in back). With all of that, you'll be fine with a 225/45 tire in front and a 255/40 width tire in back.
Old Jan 29, 2015 | 08:51 AM
Voltek's Avatar
Would I need as much camber if i did a 245 in the rear?
Old Jan 29, 2015 | 10:18 AM
deepbluejh's Avatar
You wouldn't *need* as much camber, but 2 degrees of camber is pretty moderate and is only going to help cornering grip. There is no reason to go much less for a performance setup in this car.
Old Jan 29, 2015 | 10:39 AM
s2000Junky's Avatar
Id go with the 235/40 up front personally if ap2. The shorter sidewall is nice for steering precision as well, and just a better fit overall on a 9". You can pair it with either a 245 or 255 rear. Just depends on how you want to bias the traction on the car. If it’s generally a stock suspended s2k, the ap2 take kinder to more tire up front to balance the traction bias. Ap1, generally less up front, or more in back/vice versa.
Old Jan 29, 2015 | 01:13 PM
Voltek's Avatar
I have an ap1 and would probably do 225 up front and a 255 in the rear
Old Jan 29, 2015 | 09:45 PM
Manga_Spawn's Avatar
Site Moderator
Yes to fender roll.
Nick.
Dec 17, 2010 07:05 AM
sil-300
Sep 12, 2010 12:46 AM
sofresh&soclean
Apr 3, 2010 04:11 PM
Whoabitchin
Dec 27, 2009 05:04 PM
[AP2-2NV]
Apr 20, 2006 07:24 PM
