17x9 offset 63
Old Jun 1, 2009 | 10:00 AM
S2KCER's Avatar
Default 17x9 offset 63
hey guys, im running a 17x9 wheel up front with offset 63 and 255/40/17 havent lowered it yet, but everytime i do a full lock it rubs, i took the wheel off and i see that its rubbing the top of the fender liner a little bit, anybody experience this? and im planning to lower it on amuse dampers, will it get any worse? and also is there a fix on this? thanks guys
Old Jun 1, 2009 | 10:17 AM
Vik2000's Avatar
Roll your fender...? Probably just minor rolling.
Old Jun 1, 2009 | 10:33 AM
s2kobsession's Avatar
I would assume he is rubbing the inner fender liner, not the part near the fender lip. You after alignment and a little more negative camber you shouldn't rub.
Old Jun 1, 2009 | 10:47 AM
S2KCER's Avatar
thanks for the quick reply guys, yes its rubbing on the top of the inside a little bit, since im not lowered right now, i plan to run some negative camber up front hopefully that will solve the problem, was thinking offset 63 was a little too far in on the front? thot i might need spacers...
Old Jun 1, 2009 | 12:17 PM
s2k dre's Avatar
yes the offset is too high for the front! More camber will will make it worse!
Old Jun 1, 2009 | 01:00 PM
Jim@tirerack's Avatar
Former Sponsor
The offset would be great on the rear. You could always run a 245/40R17 on the front and that should solve the rubbing issue.
Old Jun 2, 2009 | 09:10 PM
S2KCER's Avatar
o, so i suppose a 245 would be sufficient to clear the top part where its rubbing? and what about spacers? would that help out or are spacers no good...i was thinking 5mm spacers because tires are still in decent condition
Old Jun 2, 2009 | 09:38 PM
S2KCER's Avatar
also, is it possible to take out the inner top part of the fender liner?
*edit *
took off wheel again, its rubbing alright, slightly touching the fender as well, the negative camber idea, would that work? since the rubbing part is right where the dip is...
808_runwarrior
Jan 4, 2018 01:36 PM
RedCelica
Apr 20, 2017 10:31 AM
armodis
May 1, 2012 04:19 PM
Paperboy7777
Sep 26, 2011 01:20 PM
mwong
Aug 9, 2010 01:21 PM
