18's tire size
Old Aug 9, 2002 | 01:49 PM
dohc's Avatar
Default 18's tire size
Yo !
Who's rolling on 225/35/18 on all 4 corners ? This is an option i might go with my 18x7.5...
Thanks DOHC
Old Aug 9, 2002 | 01:51 PM
PLYRS 3's Avatar
[QUOTE]Originally posted by dohc
[B]Yo !
Old Aug 9, 2002 | 01:53 PM
PLYRS 3's Avatar
it's the wrong profile too..........................
Old Aug 11, 2002 | 06:41 PM
Racer Bruce's Avatar
You need to adhere to a tire width stagger front to back of appx. 25%; keep the rolling radius the same as stock at appx. 24.9 inches in diameter - don't change this as you will change the gear ratios, etc.
I am running OZ Superleggera rims with Bridgestone SO-3 Pole Positions:
Front: 18x7 with +45mm offset / 225/40's
Rear: 18x9 with +55mm offset / 255/35's
The tires and wheels are completely under the fenders. This is not the PERFECT offset. I do experience a very slight front tire to inner fender touch in extreme downhill / hard braking / hard turn situations and all is well with me.
Old Aug 12, 2002 | 12:19 PM
Unicron's Avatar
bruce jarrard,
How do you like the S03's?
I might try a set after wearing out my T1-s.
Yep...I would say 225/40/18 and 255/35/18 is a good size for 18 inchers on the s2000.
Old Aug 12, 2002 | 01:38 PM
socal28's Avatar
I had 18x7.5 with 225/40 tires on all four corners on my S before! It was basically my TL's setup and I just wanted to see what the wheels would look like on the S!
All I have to say is the handling SUCKED! The rear doesn't grip and any little fast corners, the rear will slide out.
But if you're just driving around town like a grandma all the time, the setup will work.
I'm with Bruce and Unicorn with the 18" setup though. (since I'm currently running that setup! )
Old Aug 14, 2002 | 01:46 PM
Jim@tirerack's Avatar
Former Sponsor
If you run the same size tire on all four corners you should run 225/40R18. I don't recommend it but at least the height is correct.
The car will oversteer with the same tire on all four corners.
JIm
Old Aug 15, 2002 | 11:46 AM
Unicron;
I like the SO-3's; they seem to hook up very well and are very good in the wet (it rains on occasion in my part of the counrty....
Old Aug 15, 2002 | 01:21 PM
sfphinkterMC's Avatar
with equal size tires the car will indeed oversteer at lower limits, but tends to break away in a smoother predictable manner. as long as u respect the absolute lower grip its IMO definitely a great
way to go for a street driver......have fun spinning the tires. this alsogives u more choice of rims with less than perfect offset.
for tracking, go the other way....get as much stagger as possible.
the bigger rears the better.
to maintain correct diameter, 225/45-17, 255/40-17 kuhmos..and
225/40-18, 285/30-18 various brands including Hoosiers will maintain speedo and ABS. of course the hard part is getting the correct offsets....just takes cash though.
Old Aug 15, 2002 | 04:23 PM
kjs007's Avatar
I was told that 40 series tires will rub with 18's?
rugsr
Mar 2, 2012 07:12 PM
Beyond_Redline
Jan 28, 2009 01:54 PM
Spec_Ops2087
Apr 2, 2006 04:46 PM
S2000 Cabrio
Sep 24, 2004 10:28 PM
bigpurp
Jun 15, 2004 11:46 AM
