18x7.5 +43 offset
Old Jul 25, 2005 | 10:08 PM
M32's Avatar
M32
Default 18x7.5 +43 offset
Hi everyone,
I have a friend who's selling a set of volks that are 18x7.5 +43 offset. Will this fit a s2000? I am planning on dropping my car too... any help is greatly appreciated!
Old Jul 26, 2005 | 07:08 AM
aggie's Avatar
Assuming all 4 wheels are the same (no stagger), I wouldn't do this. You could possibly fit 205 and 225 tires on those wheels. Any wider and I think you would rub.
Old Jul 26, 2005 | 07:26 AM
xviper's Avatar
I had 16s, 7" wide and 44mm offset with stock sized winter tires. They stuck out from the car just a wee bit and upon severe suspension compression, the tires would touch briefly.
With your 7.5" and 43mm offset and lowering, I think you would see more rubbing during normal driving conditions (bumps and dips in the road) and hard cornering.
Here's a pic of those rims on my car compared to a stock car:
Old Jul 26, 2005 | 05:14 PM
SoCalIsMyLife's Avatar
I'm running 18x9 +45 and have no rubbing issues w/ a rolled fender. You're fine
Old Jul 26, 2005 | 05:15 PM
Just make sure to roll the fender
Old Jul 26, 2005 | 05:32 PM
xviper's Avatar
Not everyone wants to go this route.
It's like saying that it's OK to have someone shoot you in the chest with a handgun.
Oh, BTW, make sure you wear a "vest".
Old Jul 26, 2005 | 10:44 PM
ASMspec's Avatar
You can also go the wider front fender route. I am tucking +35 16x7 fronts with 205/55/16 R compound tires. Do I recommend this for everyone? No, but for me this is what I wanted. See sig for the look.
+44 with an extreme drop may rub depending on what your front camber is and what brand/size tires you go with. I would suggest staying over +50 fronts. Good luck.
Old Jul 27, 2005 | 04:19 AM
Poindexter's Avatar
That isn't always the answer - that will only allow for a slightly different offset - not any offset.
Most rubbing comes from tires anyway - stick a thinner tire in there and you'll have less rubbing.
Kengthao91
Jan 22, 2013 09:30 AM
s2000_19
Mar 13, 2009 06:41 AM
dmw16
Sep 8, 2006 02:59 PM
yellowxAP1
Jun 22, 2006 11:26 AM
Leo Gets
Mar 27, 2003 10:42 AM
