18x8 +40 non staggered
Old Feb 25, 2010 | 10:10 PM
kkemp69's Avatar
Default 18x8 +40 non staggered
I have a nfr MY01 with an apex n1 exhaust so the rear of my car sits slightly higher than stock. I recently purchased a set of 4 18x8 +40 Voxx MGR's for $75 from a friend. I had a set of 4 215/45/18 kumho spts that I found in a scrap pile at a local dealership. I figured with the width and offset from what i researched here on that these tires would not work on the front so i purchased 2 215/35/18 tires for the front. Could i have fit a 215/40/18 or 225/40/18 on the front? Also should the 215/45/18 fit on the rear temporarily? I am wanting to lower my car with an Eibach Pro-kit springs what tires will i need to run to lower the car 1.0". Whats the biggest widest tires i can run lowered versus non lowered. I do not want to roll my fenders or add any negative camber as I allready know adding camber messes up your tires pretty bad and I drive this car on the street and don't have much money. Any thoughts or suggestions would be appreciated.
Old Feb 26, 2010 | 04:36 AM
BanzaiS2K2003's Avatar
this is very tricky since the offset is low and the wheels are not that wide. personally i would roll the rear and front fenders because no matter what you do it will rub because of ur offset. I have all 45 offsets on my car and I had to roll my fenders. U will get negative camber as soon as u lower ur car, there is no avoiding that. U might have to run staggered tires meaning you might need to get 225 in front and 245 in the back. roll ur fenders dude thats the only way i can see this working. good luck.
wes5otd
Nov 11, 2015 03:27 PM
xcrazyaenoyx
Nov 19, 2011 03:40 AM
RaheelQ
Apr 1, 2005 06:49 AM
TrIcKeD_oUt_s2K
Feb 8, 2005 11:45 AM
Infamous S2000
Apr 25, 2003 12:02 AM
