wheel help ASAP PLEASE
Hey guys. I found a set of wheels I want but idk if theyll fit there
18X8.5 35etfronts
18X9.5 40et rears
73.1 center bore
I wanna know if theyll fit properly and what tire size I should go with. Please help me out
18X8.5 35etfronts
18X9.5 40et rears
73.1 center bore
Not without a serious fender roll tab relo and a good alignment. It is possible but it won't be easy. Tires a 225 up front and a 255 for the rear. It's doable you just have to make sure these things are done correctly.
The fronts are more aggressive fitting, and will require a roll plus a bit of a stretch on the tire to clear safely, so 215's. You can fit more rubber up front if you plan on pulling the fenders, but 235/40 would be about it. The rears you can fit a 255 with just the basic roll and bumper tab relocate. Make sure your camber is at least -2 up front and -3 in back.
You should be fine with the camber. Just make sure that when you get an alignment that your front toe is set to 0 and the rear total toe is no more than a quater inch.
I am unsure how much camber you will need but it all depends on ride height.
