215/45/17 Rubbing issues?
Old Jul 11, 2006 | 12:22 PM
inlinepro1's Avatar
Default 215/45/17 Rubbing issues?
Hey guys, im about a week from purchasing some Advan RG's and i wanted to run stock AP2 tire (bridgestone RE050) and tire sizes. 215/45/17F and 245/40/17R but i am afraid i am going to rub. The offsets on the RG's are +48F and +50R. The car is pretty low, so just wanted to see everyone's input. Thank you.
-Chris
Old Jul 11, 2006 | 12:29 PM
inlinepro1's Avatar
Also what is the ideal tire pressure for the RE050's? i.e S02's are 32front and 35rear (cold)
Old Jul 12, 2006 | 07:40 AM
aggie's Avatar
I've been running fine with that offset and tire size for years. I 'think' I rubbed with 225 ES100's, but the only evidence was a missing liner connector.
Old Jul 13, 2006 | 01:16 PM
mwy23's Avatar
i rub on hard compression w/ a 215/45/17 up front on a +48 offset wheel. SO3 tires. i'm lowered to ~1finger wheel gap.
if you want to avoid rubbing and want this tire size, you need to either get a tire that isn't so squarish (toyo, yoko, mich) or run a more aggressive offset than stock.
Old Jul 13, 2006 | 02:14 PM
inlinepro1's Avatar
Hm, but a S03 is a "wider" front tire than OE Spec Potenza RE050 am i correct? Jim@tirerack, any feedback? I already rub on pretty hard compression as well on stock tire sizes. Thanks for the replies
nosjunkie
Feb 9, 2012 09:05 PM
kchandra
Nov 25, 2011 11:52 AM
RedSunS2K
Jun 9, 2010 06:47 AM
BLanham
May 13, 2008 11:43 AM
fpdok2
Nov 9, 2004 02:39 PM
