fitting wide tires
Old May 12, 2008 | 05:50 PM
BLanham's Avatar
Default fitting wide tires
I plan on buying some rims soon. The sizes of the rims are as follows:
Front: 17x7.5" with a +49mm offset
Rear: 17X9.5 with a +65mm offset
I am wanting to run a 275 wide tire in the rear and a 215 wide tire in the front. I was just wondering, which size profiles would i need for the heights in order for them to fit and not rub. I'm lowered on Skunk2's as well. I was thinking maybe
Front: 215/45 17
Rear: 275/40 17
Will these sizes look weird or fit wrong, maybe different heights? Please feel free to leave any comments, all help would be appreciated.
thanks
Old May 12, 2008 | 05:56 PM
Flite's Avatar
I think that 275 will be a taller tire than the 215.
Why do you want to run such a drastic stagger?
Old May 13, 2008 | 01:56 AM
ZDan's Avatar
Clickie the Tire Rack banner above and do a search on tire sizes in Max Perf and Extreme Perf (assuming that's the type of tire you want/need).
You'll find that the 275/40-17 is about an inch taller than the 215/45-17 stock front or 245/40-17 stock rear sizes. If you do go with 275/40 rears, you probably want 225/45 fronts (still a big diametral difference at .7"). You'll also find there's a much bigger selection of 255/40-17 tires than 275/40's.
Old May 13, 2008 | 10:13 AM
BLanham's Avatar
Well i saw a 275 wide tire today on an m3 and definately do not want that wide. I want something wide but in the same time not over the top. I think a 255 wide tire in the rear will do just fine for me. Now if I run a 255/40 17 in the rear with a 225/45 17 in the front I should be good right? The wheels I am planning to get are SSC comps. 17x9.5 +65 for the rear. I was just going off of the tire size chart on here and thought the 275's would fit because of the offset on the SSC's. I want both front and rear tires be almost identical in diameter. Please let me know what you guys think.
Old May 13, 2008 | 10:23 AM
ZDan's Avatar
http://www.tirerack.com/tires/Spec.jsp?mak...ire%3D54WR7Z1SS
225/45-17 and 255/40-17 are the same height.
215/45-17 and 245/40-17 are also the same height.
215/45-17 fronts with 255/40-17 rears would give you slightly larger-OD rears, but not a biggie IMO, so you might consider that option as well.
Old May 13, 2008 | 10:48 AM
petawabit's Avatar
would the 9.5 +65 with 275 tire in the rear clear the suspension?
Old May 13, 2008 | 11:43 AM
deathsled's Avatar
I put 255 azenis on my rear and drove with that setup for months before my fronts finally wore out, which I then did replace with 225s, but I had no problems with the 215s. Actually, I think I experienced sharper turn in due to the smaller sidewall.
The only con about that setup that I can think of was that during the winter while under hard breaking on less than perfect surfaces (bumpy or loose sand or salt) I could get the ABS light to light up. It would go back out after the car was restarted and not come back on again until I put myself in the exact same scenario, braking hard with on a surface with poor traction.
ryan2103a
Jan 30, 2012 10:12 AM
jsingh03
Jan 3, 2011 06:55 AM
duff0000
Aug 10, 2006 08:23 AM
inlinepro1
Jul 13, 2006 02:14 PM
fpdok2
Nov 9, 2004 02:39 PM
