245 45 R16
Old Mar 27, 2006 | 06:03 AM
np2k1s2k's Avatar
Default 245 45 R16
If you go from the stock tires to a 245/45/R16 tire in the rear, how much faster (if any) will our 60 foot times be? Please help thanks
Old Mar 27, 2006 | 06:14 AM
Wisconsin S2k's Avatar
same as stock.
not to mention this is totally dependent on driver anyways.
Old Mar 27, 2006 | 06:20 AM
Lionheart's Avatar
The smaller the diameter of the complete wheel, the quicker the acceleration but less top speed!? Is this correct? So a 14" wheel will make the car accelerate more quickly then the same car with for example 20" wheels...
Old Mar 27, 2006 | 07:14 AM
yeah but a 245/45/16 is barely any smaller than stock.
Old Mar 27, 2006 | 07:16 AM
Jakup's Avatar
Correct me if I'm wrong, but the stock 225 SO2's actually have a 245-size contact patch, so basically they are 245's. This is why people usually replace them with 245-sized tires when going with a different model.
Old Mar 27, 2006 | 08:09 AM
clawhammer's Avatar
Going to a 14" wheel is kind of like adding gears, except you also benefit from having less rotational mass.
Old Mar 27, 2006 | 08:27 AM
xviper's Avatar
Wheel diameter isn't what changes gearing. It's the diameter of the tire you put on that wheel.
EG. If you take a 16" wheel with the stock 225/50/16 tire on it and compare that to an 18" wheel with a 225/35/18 tire on it. The 18" setup will have better gearing for acceleration.
To answer the original question ........................ you won't accelerate any quicker. A 225/50/16 tire is almost the same diameter as a 245/45/16 tire. If you could get a 245/35/16 tire, then you would have an advantage, but your car would look really stupid.
Old Mar 27, 2006 | 11:34 PM
dubcac's Avatar
I think he was talking about traction and 60' times, not acceleration. However, as stated above, the OEM 225's have the same contact width as non OEM 245's...so it will be about the same. Now, if you get some 245 drag radials, your 60' will go down considerably...if you can drive.
Old Mar 28, 2006 | 06:57 AM
np2k1s2k's Avatar
I did mean traction but thanks for all the info. I didn't know the stocks were same width as 245 aftermarkets.
McD Effect
Jun 19, 2009 07:57 AM
jmorale1
Jun 22, 2008 03:54 PM
Davidss
Jan 26, 2007 02:38 PM
CwestinAP1
Mar 5, 2005 09:10 AM
Tireguy
Oct 27, 2003 03:21 PM
