255/40r17 all around ?
Old Feb 21, 2012 | 03:30 PM
Newformulaap1's Avatar
Default 255/40r17 all around ?
Just got my downforce front fenders and was wondering what would need done to the rear fenders in order to fit a 17x9 +38 running a 255/40r17 or would there be a better setup ? Thanks ahead for any advice.
Old Feb 21, 2012 | 05:38 PM
burglrdrift's Avatar
im struggling with the same set up in the rear. are you on coil overs?
Old Feb 21, 2012 | 05:39 PM
spdracerut's Avatar
In your case, running a 255 wide tire is pretty irrelevant as you're running such a low offset wheel. A +63 fits pretty much the same as stock. A +38 pushes the wheel out 25mm, which is basically 1". I think the wheel itself will be past the fender. In short, your fender will probably require a lot of work along with a lot of negative camber.
Old Feb 21, 2012 | 06:10 PM
no coil overs yet, pretty much just starting on this. Is there a size anyone would recommend that would look good with the downforce fenders and a rolled rear fender ?
Old Feb 21, 2012 | 06:29 PM
ryuken's Avatar
A 245/40 will give you a slight stretch which could give you some clearance vs a square 255/40.
Old Feb 21, 2012 | 06:38 PM
yes, but what about as far as rim size? I haven't bought wheels yet, so I'm just trying to figure out a setup that will work for sure when I do put a new suspension under it and also fill out the downforce fenders.
Old Feb 21, 2012 | 07:27 PM
c32b's Avatar
am running +45 255/40/17 at the back on stock fenders with tein coilovers. camber is -3.0. You need to relocate the rear tab & pull/slightly flare the rear fender with a full roll
Old Feb 22, 2012 | 05:33 AM
Do you think a 17x9 +45 running a 245/40 would be easier, would it fill the downforce fenders?
Old Feb 22, 2012 | 06:23 AM
Ouhei's Avatar
It'll fit easier because it's a less aggressive wheel offset. I run 17x9+45 w/ 245/40 on stock fenders with just a good roll and a bit of camber (-2.5 up front -3 in the rear). I could probably go with a 255/40 if I wanted.
The Downforce fenders will fit that 17x9 + 38 just fine (are we talking about RPF1's here? Because they have a 17x9 +35 and a 17x9.5 +38 but not the size you post). There are a bunch of people running 17x9.5 +38 with a 255 in the back; you'll need to roll the inside of the fender flat, relocated the bumper tab and trim your bumper to have it fit and you'll want to run at least -3 camber. This is all if you're lowered, if you're at stock height it'd be a bit easier.
Old Feb 22, 2012 | 07:14 AM
I haven't decided on a wheel yet, just trying to decide what specs to look for. I want something that's somewhat flush and would like to run a non staggered setup, I'm willing to roll the rear, I just want to make sure the front doesn't look sunk in with the downforce fenders, I went ahead and got the fenders because someone had done me the favor of running into my drivers front fender overnight and I figured I might as well get wider ones.
revoluzion9k
Jan 20, 2016 12:49 PM
mrbond413
Aug 16, 2012 03:56 PM
starbai
Nov 24, 2009 01:52 PM
chhatre9
Dec 11, 2008 06:23 AM
dwedge
Dec 27, 2007 10:36 AM
