275 rears on an AP1
Old Jun 13, 2012 | 01:30 PM
calebzimm's Avatar
Default 275 rears on an AP1
I'm wanting to run a wider set of rear tires on my AP1. I'm currently running 225s out front and 245s in the rear. I'm wanting to stick with the same tires and move my 245s to the front. The next size up I've found for my current tires are 275/40s. with a 17x9 +45 wheel is it even possible to fit these in the rear without cutting the fenders or is a roll and tab relocation sufficient?
Input is appreiciated.
Caleb
Old Jun 13, 2012 | 02:50 PM
Froth.'s Avatar
17x9 +45 with a 275 is going to rub, LOTS. Even a full roll/relocation/negative camber may not 100% clear them. It will be close and require LOTS of rear fender work, much of this depends on ride height as well.
Old Jun 13, 2012 | 02:58 PM
calebzimm's Avatar
that's all I needed to know. I'll see if I can order my tire in a custom 255
Old Jun 13, 2012 | 03:41 PM
Y0N1P8T5R1F5A4T's Avatar
What do you mean custom 255?
Old Jun 13, 2012 | 04:44 PM
dc2-2-ap1's Avatar
You would need a rim that is around 9.5+65 or 10+70 to fit those tires.
Old Jun 13, 2012 | 08:53 PM
calebzimm's Avatar
my particular brand/style of tires jumps from 245s to 275s...or at least that's all I can find.
edit: a little more searching and I found some 255/40 17s same style
joshf47
Jun 16, 2013 03:31 PM
thenoxus1
Apr 24, 2013 06:19 PM
vietdragontekx
Dec 28, 2010 12:00 PM
vtec88
Mar 5, 2010 04:46 PM
dan_uk
Aug 7, 2009 03:09 PM
