5Zigen Hyper 5ZR 18x7.5 +48offset
Old Jun 4, 2004 | 10:04 AM
NiN's Avatar
NiN
Default 5Zigen Hyper 5ZR 18x7.5 +48offset
I'm thinking of getting the 5Zigen Hyper 5ZR that only available in 18x7.5, highest offset is +48. Would there be a fitment problem as I'm lowered around 2inch with Bilstein PSS. Also what tire size do people recommend, 225/40/18 front and 245/35/18 rear are closet to stock wheel ratio?
Old Jun 4, 2004 | 07:02 PM
Zach H's Avatar
If you have 7.5" all the way around, the widest you can go in the rear is 225. Those wheels will rub if you don't roll your fenders btw.
Old Jun 7, 2004 | 05:17 AM
SolReborn's Avatar
also, remember that those wheels are much heavier than your stock wheels!
Old Jun 7, 2004 | 08:53 AM
NiN's Avatar
NiN
so will 245/35/18 tires rub in the rear? What would the effects be if running 225/40/18 tires on all four corners?
Old Jun 7, 2004 | 10:12 AM
Zach H's Avatar
245's won't fit on the rim. You will have a little more oversteer when running same width tires front and rear. You won't really notice the effects until you start pushing the car pretty hard.
Tassill
Jan 9, 2010 11:48 AM
kylemonster85
Mar 12, 2009 08:24 PM
NATURAL JOCK
Apr 17, 2007 11:48 AM
HondaS2000Tuner
Feb 3, 2006 08:10 PM
dkhl
Sep 18, 2001 11:30 AM
