8" Rears... ? Why ?
Old Jan 26, 2007 | 07:47 PM
nj2tn's Avatar
Default 8" Rears... ? Why ?
I've been looking for wheels and it seems like a ton of wheels that I like are only x8 in the rear. Seems pointless for me to go from my 8.5 ap2 wheels to an x8.
Thoughts ?
Old Jan 26, 2007 | 08:08 PM
GrandMasterKhan's Avatar
you must be looking at cheap wheels or wheels not made for the s2000 in mind then. Most of the proper rears made for the s2000 will be min of 8.5 to 9"
Old Jan 26, 2007 | 08:28 PM
nj2tn's Avatar
I saw a few sets of works w. the x8 in teh back...even a set or two of volks too.
Old Jan 26, 2007 | 09:18 PM
S2K 4 ME's Avatar
Thats not always true......mine are 18x7-18x8 +50 and run perfect, no rubbing , flush etc.
Old Jan 27, 2007 | 01:26 AM
WashabiS2K's Avatar
im running 18x8..... in the front
Old Feb 4, 2007 | 11:06 PM
nj2tn's Avatar
bump...I found another set I like...17x8 again the back...
hrm.
Also, the rears are 17x8 +50 but I have the option of 17x7 or 17x7.5 in the front.
Should I go for the larger size up front or somthing that creates a bigger stagger ?
Old Feb 5, 2007 | 05:10 AM
sprix!'s Avatar
I would go for a larger stagger personally. I would not do less than an inch difference. No more than 2 inches difference. I have an inch and a half personally. (18x8" in front and 18x9.5" in back.) Most people want to run wide tires in back, and with a width of 8 inches, you would really be wise to not exceed a 245-40-17. Which isn't bad... just not as wide as some like.
Old Feb 5, 2007 | 01:11 PM
mic_crispy's Avatar
I ran 17x7 and 17x8 on my ap1.... which was wider than the stock rims (ap1 rims)...
But i can see your concern reguarding ap2 rims... it would seem abit pointless to pay for rims that arnt even as wide as your stock rims... and from what ive read, its better to run.... say a 245 on a 8.5in rim rather than a 8in rim.. because the tire sits better.... but that may just be a myth..
Old Feb 7, 2007 | 07:30 AM
AP2's Avatar
AP2
yeah a 245 is probably as wide as you can go on an 8 inch wide wheel...
vincengf
Nov 30, 2013 10:25 AM
JhammS2K
Feb 14, 2013 04:01 PM
fergie1471
Aug 1, 2009 12:51 PM
rev9jm
Feb 20, 2008 10:08 AM
watermain
Mar 16, 2005 10:46 AM
