Adjusting coilovers
Old Aug 12, 2006 | 05:03 AM
Jonnypsyc's Avatar
Default Adjusting coilovers
I just got tein coilovers installed on my car. What is the correct way to adjust the coilovers so that both side (left & right) are the same (or close to)
measuring the length of suspensions?
or the distance from fender to tire?
When i have the same length of suspensions on both sides, the distance from the fender to tire is not the same. So i have to make one side shorter than the other to make the gap between tire and fender the same on both side.
Please let me know which is correct way to do it
thanks
Old Aug 12, 2006 | 05:15 AM
CoralDoc's Avatar
The correct way to do it is to take the car to a suspension specialist and have them corner-weight the car. You'll need to decide what ride height you want first. Measuring to body panels may be aesthetically pleasing, but may not be correct for optimum performance.
Old Aug 12, 2006 | 05:32 AM
negcamber's Avatar
What Josh said
You will need to find some race team shops in your area and call to ask them if they can do corner balancing or if they know a shop in your area that does. If you call a normal mechanic or alignment shop they probably will not have any idea what corner balancing is.
Did a quick search for you...not sure how far Berryville is from you, but here is a shop that can corner balance for you:
http://www.kingratmotorsports.com/services.php
Old Aug 12, 2006 | 06:44 AM
rijowysock's Avatar
corner balance.
or if thats too much
let settle..
measure ground to fender... find out what u need to raise/drop.. write on hand and then when up in air change that.. drive and settle and sit back and enjoy.
riley
Old Aug 12, 2006 | 06:47 AM
rijowysock's Avatar
after clicking link
holy crapola.
corner balance and alignment adjust/check for 100$$
i pay 125 for just toe/camber/caster front toe camber rear.. (supposed to be 175 but i get discount)
anyone know a place like this in florida?? cause i pay an added 100 for corner balance
Old Aug 12, 2006 | 07:10 AM
Jonnypsyc's Avatar
thanks guys,
i'll call some auto racing shops in the area to see if they do corner balacing.
Old Aug 12, 2006 | 10:00 AM
Dr. WOT's Avatar
Originally Posted by rijowysock,Aug 12 2006, 02:47 PM
after clicking link
holy crapola.
that's a smokin deal! I think I paid about $185 when I had my Civic aligned/CW'd a few years back.
Zygrene
Nov 1, 2013 11:30 AM
chillout18
Apr 1, 2008 10:12 AM
bkmagby
Feb 22, 2006 05:55 PM
kevsS2
Oct 8, 2004 01:51 PM
CMiS2K
66
Apr 1, 2003 06:44 AM
