ADR Wheels
Old Dec 18, 2005 | 03:49 PM
S2K 4 ME's Avatar
Default ADR Wheels
I'm curious if anyone has had any experience with these wheels, and why they are so inexpensive? I've been looking for some 03' rims to mount snow tires on, but for this price I may just go ahead and mount the snow tires on my OEM rims, by these in an 18' and mount performance tires on them.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...TRK%3AMEWA%3AIT
Comments or feedback appreciated. Thanx in advance.
(I know this sale has ended)
Old Dec 18, 2005 | 04:17 PM
xviper's Avatar
I've used ADR rims for snow tires before (for almost 5 winters). They are cheap because they are not a high quality rim. The paint on the centers will peel off in big flakes. The backside is not well protected and will get badly corroded with winter's salt and crud. They take quite a bit of weight to balance them well and they don't resist nicks and mild rubs very well. However, for the price, I thought they were a great looking wheel. Mine were 16" X 7" with 44mm offset, cost $95.00 Cdn each. Offset wasn't great but worked well for snow tires in the stock sizes. A much better alternative to getting black steel wheels that aren't the exact fit either.
Old Dec 18, 2005 | 05:24 PM
spa-zz's Avatar
Originally Posted by S2K 4 ME,Dec 18 2005, 08:49 PM
... by these in an 18' and mount performance tires on them.
For the record, you should avoid wheels without a stagger if you plan to be using them as your performance set. If you limit yourself to a 7.5" wheel on the rear, you're limiting yourself to about a 225 mm wide tire on the rear, and then you really should run something narrower than that in the front to maintain proper handling balance. You'd want to read the sticky about tire sizes and pick accordingly.
Read the wheel fitment guide:
https://www.s2ki.com/forums/index.php?showtopic=342793
and the tire sizing guide:
https://www.s2ki.com/forums/index.php?showtopic=48572
Cheers.
Old Dec 18, 2005 | 05:31 PM
xviper's Avatar
Cheers.
ADRs are not going to make a good "performance" rim for the reasons I stated. They are not of high quality and may not take the stress of performance driving. The balance alone, may be a huge issue.
Old Dec 18, 2005 | 05:54 PM
S2K 4 ME's Avatar
Cheers.
Thanx for the info guys.
I'd definatly stagger them, I was just using that ebay sale as a reference.
Since we're on the subject, I've read the fitment guides above and understand that I have 7' wides in the front and 8 1/2' wide rims in the back, but I didnt see anything about what the offset is on the OEM rims, what is it???
Old Dec 18, 2005 | 08:46 PM
spa-zz's Avatar
55 mm front, and 65 mm rear, for all model years. I'll add that to the guide.
Old Dec 18, 2005 | 09:14 PM
S2K 4 ME's Avatar
Thank You!
Old Dec 22, 2005 | 02:58 PM
stocky's Avatar
Cheers.
Sorry but that fully correct.
You can run non-staggered setup on the S2000 without any problem.
Just make sure that you never go smaller than 225 in the back.
It's all about your geometry and depends on your driving style
I've tried it all on the S
205/205 205/225 205/245 225/225 215/235 235/235 225/255 225/245 in 16 /.17/18 etc...you name it!
But for normal road use and normal driving style I agree, bette ris larger at the back
Old Dec 22, 2005 | 05:38 PM
spa-zz's Avatar
I assume you meant to say not fully correct?
The guide clearly states that it is a recommendation, not a law.
Cheers.
Old Dec 24, 2005 | 08:17 PM
tru's Avatar
tru
offset will depend on the width of the rim 55,65 is for 8",9"
zeroptzero
Southern Ontario For Sale
May 19, 2018 05:11 PM
vtecowner
Nov 29, 2011 10:10 PM
themadchef
Aug 29, 2003 10:37 PM
Mannn
Jul 9, 2003 05:28 AM
sunsponge
Oct 25, 2002 07:58 AM
