Advan Model 5's
Old Mar 2, 2005 | 01:49 PM
lude2S's Avatar
Default Advan Model 5's
Always been a huge fan of these rims and was wondering if anyone had them on their S. Will these rims work on our cars?? Where would i be able to get them from?? Thanks
Old Mar 3, 2005 | 11:57 AM
Jim@tirerack's Avatar
Former Sponsor
I have not seen them. As far as I know the Advan name is Yokohama's performance tire name. I do know they have some wheels in Japan that are not available here.
Old Mar 4, 2005 | 04:42 AM
Double_L's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I don't think Advan Model 5 has the correct offset for our S2000... Front might be fine, but probably not the rear... Good luck!
Old Mar 4, 2005 | 10:09 AM
l8brakr's Avatar
Try here and they're even a sponsor: http://www.gruppe-s.com/Advan/advanm5.htm
You could get away with the 18x7.5 +50 all around if you really wanted to or the 17x7 +45 front and 17x8 +45 rear would work but the fitment in the rear would need some help because it may rub with 245/40's.
Old Mar 4, 2005 | 05:32 PM
lude2S's Avatar
ok, well i want to go with atleast a 18" rim, So these are out. I have 19x7.5 right now with +45 offset and 215/35 tires all around. I like my RH C3's but the only reason i'm looking to sell is get something a little wider for the rear. So basically i've narrowed it down to LE37T's then. I will either go F-18x7.5 and R-18x8.5 or 19x8 all around. Can anyone shed some light on which offsets i am best to go with with each style rim?? With the 18's i would probably go 225-F and 245 to 255-R with the 19's i don't know what i would go or be able to go. Thanks for your help.
tugsta
Jun 14, 2011 05:34 AM
keefss2k
Jul 7, 2009 05:37 PM
phishphreak1234
Jan 13, 2006 06:43 AM
LudeAtic
Jan 26, 2005 12:59 PM
B SweepeR B6
Sep 27, 2004 09:55 AM
