Advan RZ set up
Old Jun 4, 2008 | 11:07 AM
TheRiceBoy's Avatar
Default Advan RZ set up
Sup everyone, i just bought my S2k a week ago and looking put some new wheels on it. I like the Advan RZ but i'm not sure of the offset. I would like to go with 18x8 +37mm (front) and 18x9 +35mm (rear), i'm trying to go for an aggressive look . Is this set up ok or will it rub?
Plus any suggestions on which color would look best on a Platinum white? THanks
Old Jun 4, 2008 | 11:13 AM
Terror's Avatar
I think the Hyper Silver RZ's look the best. If you want an aggressive setup, I would do 17x9 +45 in the front and 17x9.5 +30 in the back. You might need a set of Over Fenders for the rear though.
Old Jun 4, 2008 | 11:18 AM
TheRiceBoy's Avatar
Thanks but what if i want to install 18's or is it to much?
Plus i'm with you on the Hyper Silver i'm also considering it, either that or Bronze
Old Jun 4, 2008 | 11:22 AM
Terror's Avatar
If you want to do 18's, you might very well rub with the sized I gave you. Although I can't be sure.
I'm sure with some camber dialed in, as well as a front fender roll, you could do the 18's.
Old Jun 4, 2008 | 11:27 AM
TheRiceBoy's Avatar
Thanks for the advice i'll post my progress with pics
Old Jun 4, 2008 | 12:26 PM
Dressed2Kill's Avatar
You will need to roll and flair your fenders along with running -2.5* of camber in the front and at least 3.0* in the rear depending on how streached your tires are. Then depending on how low you go, you will need to reloacate your rear bumper tab. You may still rub if you are low enough and drive on bumpy roads.
Old Jun 4, 2008 | 12:38 PM
Dr Jekyll's Avatar
dont do 18's they are just too big for the car
Old Jun 19, 2008 | 05:43 AM
TheRiceBoy's Avatar
what do you guys think if i went with the following setup:
Suspension: KW V2
Wheels: "Advan RZ" 17x9 +35 all round (Bronze)
I would like to have my rear tyres tucked in probably have the car lowered 2 inchs. Any thoughts
Old Jul 10, 2011 | 06:44 AM
User 62123's Avatar
Suspension: KW V2
I run this same setup (custom silver wheels though) with rolled fenders 1.5/2.0 camber, 1.75 inches for flushness, and have no problems with rubbing. Run 2.0/2.5 camber if you want them tucked as mine are literally flush with the fender. I say go for it as the RZ's are bada$$!
Old Jul 10, 2011 | 09:42 AM
S2K-F8's Avatar
Originally Posted by SYR_S2k
Suspension: KW V2
I hope after 3 years that he got it figured out lol
gofast182
Mar 29, 2018 10:49 AM
KW888
Feb 9, 2017 12:32 PM
bloodf0xx
Jan 13, 2017 03:02 AM
bspec
Dec 3, 2009 11:49 PM
octechgeek
Dec 2, 2007 09:52 PM
