Some advice on ideal new wheel offset set up.
I've currently running standard set up ride height etc I've just ordered a set of Works S1 3 piece. So because the car is so clean and low mileage with all the dealer history I don't want to cut any arches etc a slight roll is fine. The question is can anyone tell me what would this be the best set up 18x9.5 et37 for the rears (Decided ish) and 18x8.5 et41 for fronts or the other option would be 18x8.5 et29 fronts? Thinking the rears is perfect. I'm leaning towards the et41 for less work. Not looking the Hella Flush or Stance look but want to keep the driveablity and performance the same. Many thanks
Lol. 8.5 +41 needs more than a "slight roll" same with +39 9.5 for the rear. The fenders have to be rolled flat and the tabs relocated. +29 doesn't fit at all. Read the fitment sticky. These are far from ideal especially at stock ride height.
You plan on staying stock height? If so, aggressive fitments won't look good. 9.5" +37 rear with stock camber will stick out PAST the fender.
Size chart: https://workwheelsusa.com/wp-content...ZING-CHART.pdf
Based on your goals, I would have gone with 8.5" +54 A disk front and 9.5" +62 O disk rear with 225/40, 255/35 tires. If you are willing to lower the car and roll the fenders then you can go more aggressive.
Thank you for your reply. yes I understand the involvement in the rear wth relocating the bumper tab to a different place and a full roll and tyre option has been considered for the rear. Suspension I know will have to be worked on. But for maximum dish effect is the above off sets the best recommend in you opinion? I think 37et on the rear is the max I can do with out cutting arches etc. The front 29et would of been a more later on useable set up but I was told the work involved would of been a lot while the 41et would be much easier. Thoughts ?
Did you already order the wheels in those specs?
Those specs can work, but at stock height will be poking and will not look that good. That setup is more for S2000s on coilovers who plan on rolling their fenders and relocating the rear bumper tab. If you are concerned about lip size, then I guess yes those are your best options to get a decent size lip. But be prepared to due some work to your fenders and add camber.
If you read the above I have purchased but haven't confirmed the offset as when I DID PURCHASE I had a bit of tweaking to re think to it because the first offset I was planing to order became a problem when deciding on the final factor of the amount of work needed.
as for MY QUESTION was should I purchase more for later or saleable offset or do I make the wheels a more S2K set up. I was also asking for advisable advice on the maximum people would go without using cutting methods or ruining the car just to get a larger diameter wheel on.
Purely opinions of the front offsets I have put out above if it was there choice.
