alignment?
Old Jul 17, 2014 | 12:06 PM
Jasoons2k's Avatar
Default alignment?
I just bought the evo v12s from tirerack and got them mounted, balances, and aligned. I choose to go with the 225/255 set up as the price was very low for these sizes. I have a 2005 completely stock with ap2v1 rims with stock suspension. These are the numbers: Left and right Front- -0.5 Camber / 5.9 Caster / 0.00 total toe, Left Rear - -1.6 Camber / 0.15 Toe, Right Rear- -1.4 Camber / 0.19 toe / -0.02 Thrust Angle. I daily drive the car and just want to make sure the guys did a good job, they seem to not cared when I told them the tires were not spec size, replying with "that is fine," to some of my questions.
Old Jul 17, 2014 | 12:32 PM
1nate7's Avatar
Looks fine to me - it's just a stock spec alignment. You could probably run a little less toe in the rear to help with tire life but it's nothing to be that concerned about.
Old Jul 17, 2014 | 01:03 PM
Jasoons2k's Avatar
Thank you 1nate7, feel better knowing its done right.
Old Jul 17, 2014 | 01:15 PM
ZDan's Avatar
Yeah, what he said. Personally I run max achievable camber (currently -1.2 front, -2.2 rear) and zero front toe, 0.2degrees total rear toe. But you're in a good place IMO. As long as the 0.15/0.19 rear toe figures are in *degrees* and not inches...
Old Jul 17, 2014 | 01:21 PM
Jasoons2k's Avatar
They are, thanks for the help
JUSTINTHECOASTIE
Sep 20, 2012 09:55 PM
JUSTINTHECOASTIE
Apr 6, 2012 11:48 AM
SXYS2k
Dec 6, 2011 09:51 AM
RazorV3
Nov 14, 2004 08:18 AM
gerryk
Oct 19, 2003 09:46 PM
