Alignment Settings
Old Nov 19, 2004 | 05:48 AM
redlineracing's Avatar
Default Alignment Settings
Need to get "Neutral" camber alignment settings for my 03.
Tires are wearing too fast!
Thanks
\rlr
Old Nov 27, 2004 | 10:25 AM
RACER's Avatar
Welcome to the club
Maybe reduce your camber settings front and rear a little bit?
Old Nov 29, 2004 | 12:43 PM
GChambers's Avatar
Banned
I think the correct camber settings for you also depend on your driving habits. If you drive more aggressively, you may want a bit more camber. If you do more highway driving, you may want less.
Old Nov 30, 2004 | 05:54 AM
Oversteer's Avatar
Toe can be blamed for most of the rear tire wear, very aggressive on the S2000.
If you autocross or track your car and are a reasonably good driver less rear toe will make your tires wear less and your car more tail happy.
(Very scary at the limit for the tipical driver)
All this can vary depending on what tires, sway bar, springs you have.
I keep it within the Honda recomended range of toe but on the lower side.
Old Nov 30, 2004 | 06:36 AM
natedoggs2k's Avatar
I had my car aligned to Honda specs, and I have had no problems. No uneven tire wear, no premature wear, no handling problems. I am very satisfied and highly recommend using Honda specs as long as a reputable shop with a good alignment machine does the job.
I had mine done at Acura, as they have the best machine in north central Florida, and the mechanic spent time making sure it was perfectly aligned.
Old Nov 30, 2004 | 11:04 AM
mosesbotbol's Avatar
The Euro alignment specs are twitchy on the highway, and make sure where ever you get the alignment, you sit in the car while they do it. You'll be blown away how much your car changes geometry when you sit in it.
Aliminator
Jul 16, 2012 07:00 PM
TR-S2K
May 7, 2008 05:07 AM
kylemonster85
Apr 29, 2008 12:30 PM
Scot
Sep 2, 2004 07:17 PM
Squeezer
Mar 28, 2003 09:32 AM
