Alignment/Tire wear/Rubbing - Help Please
just got an alignment today and was wondering if you guys had opinions on the following:
current camber is as follows: FL -1.0 FR -.08 & RL -2.2 RF -2.0
and i am rubbing just a bit.
will going a bit more negative on the camber solve the rubbing issues? and how much will this be a detriment to or create excessive tire wear for me.
am on PSS9s - lowered about .75 inch
other specs are - Front 18x8 +50 with 225/40 & Rear 18x9.5 +55 with 265/35
thanks for your comments....
did you relocate the bumper bap on the rear bumper and shave your fenders. Im running 18x10.5+39 with -2.9 camber and almost slamme on tein flex with little to no rub only when I run over something really big. With those specs you should be able to pull it off easily.
