Tire / Alignment Help
Old Nov 24, 2011 | 10:15 AM
corpuszero's Avatar
Default Tire / Alignment Help
I have an AP1 and am currently running 17x9 +45 RPF1s all around (non-staggered)
The front tires I am running 235/40/17 and rears are 245/40/17
Alignment is set at 0 degrees toe and front camber -1.8 and rear camber -2.6
Got the front fenders pulled and rears rolled, and am lowered on Eibach Pro Kit + Koni Yellows (lower perch)
Is this setup the best way to get the most life out of my tires while still maintaining a "flushed" look?
I am getting a lot of camber wear on the inside of the tire, but that should be expected right?
Do you guys think I can have the camber adjusted to get more tire life without rubbing? Or maybe a change in Tire size?
If theres any more information I need to give, just let me know!
I'm really a noob in this area, so ANY advice would be appreciated, thanks!
Old Nov 24, 2011 | 10:37 AM
corpuszero's Avatar
nevermind, I think I will go with this route.
https://www.s2ki.com/s2000/topic/909...tiresworth-it/
Searching FTW!?
Old Nov 25, 2011 | 09:13 PM
rrounds's Avatar
My alignment is(now) on my '06
front camber 0(L/R) tow 0
rear camber -1(L/R) tow 0
I hope this gets me longer tire wear as I put over 30k miles on my "S" a year and so far I don't notice to much difference in how the car feels on the "street". If it was on the track I know it would not be as fast with this alignment but I would still be faster than a lot of other cars out there.
It all depends on how you drive your car and what you want out of it and how much you are willing to spend on tires for 1 or 2 seconds at the track. I don't track my car but I do drive it on some very fun roads and I like to have fun. I have driven my car with this alignment in the rain and unless I drive like an idiot the car is just fine. If my car was tail happy then I would get some tow in the rear. Again if you track your car this alignment is not a good one for the track.
ROD
Old Nov 26, 2011 | 04:17 AM
Mark355's Avatar
Is is true that aggressive toe eats tires more than camber? Stock toe in of 0.15" in the rear seems like a lot. Thinking of bringing that down for my next alignment.
Old Nov 26, 2011 | 06:42 AM
ZDan's Avatar
I wouldn't call .15" (.34degrees) total rear toe excessive. If it's that much per side (.3" or .68 degrees total), that will cut your tire life in half or worse.
I usually recommend ~.2-.3 degrees total, and run 0.1-0.2 degrees total rear toe myself. 2.2deg negative camber in the rear, and I'm at 10k miles on Hankook RS-3s with 5/32" tread depth remaining (3/32" to wear indicators).
theS2K
Jul 12, 2015 11:05 PM
Themikewoo
Jul 3, 2013 04:32 PM
psychoazn
Jun 10, 2012 01:23 PM
crispyhihats
May 17, 2012 07:56 AM
hypforlife32
May 1, 2011 02:05 PM
