Another rpf1 17x9 tires question
I read most of the main rpf1 and didn't really get a clear cut answer
I plan on getting rpf1 17x9 +45 all around and need help w tires size. Ap1 with Koni yellows on lower perch + eibach prokit springs
I need help deciding on tires size that won't affect the speedometer,gear ratio
1. Should I get 215/45 ,225/45, or 235/45 in the front ?
2. I know I want 245/40 in the back, how much fender work is required if any.
I'm leaning toward the stock Ap2 tire size of 215/45 front 245/40 rear. Will it make the front look too small or skinny ?
Thanks
Thanks
You will need more camber and some fender work and they won't stick out past the fender. a 215 on a 9" wheel will be pretty stretched. If you want to keep stagger then why not buy staggered wheels?
I have a 255/40/17 on +45 rpf1 on front and rear. The rears rub slightly on big dips even with the bumper tab relocation and rolling with -3 deg camber (i am running 16 kg/mm springs on tein super racing raised to stock ride height). Have decided to do some fender work to ensure no rubbing so do take note of that.
