Anyone got Rota Subzeros on their S2K?
I was thinking this also, what size where you looing at the 17's or the 16's
the 16's are the same size as the stock f 16x6.5 +36 (+55 for stock)
r 16x7 +45 (+65 for stock)
I wonder if it would work ??? has to be lighter then stock !
The spoon wheel run almost the same offset 35f and 45r but they are 7f and 8f in. wide.
Get as close to stock offsets as you can. I think for the front you want to try to get at least a 40 offset on a 7" wheel, and in the rear I think a 40 offset is about the minimum for an 8" wheel. It always depends on what tires you choose and if you are lowered or not.
I have the subs in 17x7.5 48mm all around. 225f/245r tires. I did have to have some machining done to allow for the front hub size. There were some pics from my camera phone on here somewhere. I'll try to find them. If you have any questions I'll try to help you out.
