anyone running these offsets?
Old Dec 7, 2005 | 03:38 PM
bumpinvtec's Avatar
Default anyone running these offsets?
i was wondering if anyone of guys are running a 17 inch rim in the rear with a +45 or +48 offset, i know there are rubbing complaints but i've read other post where others ran these offsets without a problem, there was one post of somebody running black racing pro N1's in a 17x8 +38 offset in the rear, i do plan on lowering but not too much, maybe a inch or inch and quarter, im thinking espelir but i wanted to get some feedback before i purchase a set of wheels, i was thinking 17x7.5 in the front in a +45 and a 17x8 inch rim in the back with either a +45 or +48 offset and running a staggered tire setup, any comments welcomed, thanks
Old Dec 7, 2005 | 03:57 PM
The Lloyd's Avatar
I'm running Gramlights, 18x8 +50 w/ Fuzion ZRi 245/40/R18s, dropped on Espelirs, with no problems at all. Rear camber is not set too aggresive either. I would imagine 17s would be no different as long as you're not running some ridiculous sidewall height... like 65 seriers or what not.
You should be okay with the +48
Old Dec 7, 2005 | 09:27 PM
onlytamiya's Avatar
I have 18x8.5 with a 43 offset and no rubbing, you should be fine with a 45 offset
Old Dec 8, 2005 | 01:25 AM
bumpinvtec's Avatar
are you lowered on springs or are you stock?
Old Dec 8, 2005 | 05:05 AM
spa-zz's Avatar
Stock height or lowered? If lowered, did you get an alignment afterwards?
Old Dec 8, 2005 | 11:37 AM
onlytamiya's Avatar
Stock height.
Old Dec 8, 2005 | 02:16 PM
spa-zz's Avatar
Originally Posted by onlytamiya,Dec 8 2005, 04:37 PM
Stock height.
What tires? Factory alignment?
Old Dec 8, 2005 | 08:17 PM
onlytamiya's Avatar
Toyo T1R 225 40 in the front and 255 35 in the rears. Stock alignment.
Old Dec 9, 2005 | 04:51 AM
spa-zz's Avatar
Consider yourself lucky. People usually rub with that width and offset. Although I think I did read somewhere around here that the Toyos run narrow, which can help.
Old Dec 10, 2005 | 10:42 AM
bumpinvtec's Avatar
is anyone out there running lowered with a +45, +48 offset in the rear
Coma-02SK
Oct 25, 2012 01:26 AM
jonner
Oct 7, 2012 07:50 AM
MickeyS
Apr 14, 2010 02:46 PM
blackfx35
Mar 7, 2006 06:24 AM
boredfast
Feb 20, 2006 06:37 AM
