anyone try 17x8 on front and 17x9
Old Feb 15, 2006 | 07:13 PM
WHEELWORKS's Avatar
Default anyone try 17x8 on front and 17x9
has anyone tried 17x8 and 17x9 for wheels front and rear?
Old Feb 15, 2006 | 07:32 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Wil fit,depending on the offsets.Try to post in Wheels and tires.
Old Feb 15, 2006 | 07:39 PM
SpeedxRacer's Avatar
You can fit x9s in the front and x10s in the rear if you have the right offsets.
Old Feb 15, 2006 | 07:41 PM
10.5s in the rear*
Old Feb 15, 2006 | 11:05 PM
dispader's Avatar
I've got SSR comps in 8" fronts and 9" rears with no problems
Old Feb 16, 2006 | 08:47 AM
Tel1sps's Avatar
What tires are you running?
Old Feb 16, 2006 | 01:42 PM
spa-zz's Avatar
It's not so much the width of the wheel as it is the width of the tire and the offset of the wheel. Reason for that is, you can run a 7" wheel or a 10" wheel (assuming the tire will fit) and the tire tread (the part that's most in danger of rubbing) will be in the same place relative to the fender.
If you have proper offsets, you can run the width wheel that fits the tire you want to use and you'll be all set.
Cooper4x
Mar 19, 2014 09:48 PM
rsxiness03
Apr 13, 2009 02:54 PM
dmw16
Aug 28, 2006 07:40 AM
RogerHinga
Jun 19, 2006 08:27 PM
