ap1 max tire width
Old Jul 6, 2010 | 12:33 AM
jo.strup's Avatar
Default ap1 max tire width
How wide of a tire can fit the stock ap1 without rubbing or anything? (front and rear)
Old Jul 6, 2010 | 03:35 AM
ZDan's Avatar
Hugely depends on wheel offset.
Have a look at the first post here: https://www.s2ki.com/forums/index.php?showtopic=342793
Old Jul 6, 2010 | 12:38 PM
Jim@tirerack's Avatar
Former Sponsor
You can safely run 225/50R16 front and 245/45R16 rear. The problem is the only tire I have available would be the Fuzion ZRI that would have matching tires.
If I can help let me know.
Old Jul 6, 2010 | 01:04 PM
TurboCongo's Avatar
Im running 245/50 nittos in the rear and 225/50s up front
Old Jul 6, 2010 | 05:27 PM
jo.strup's Avatar
I've got 235/45r17's in the rear now and 215/45r17 in the front, and I'm thinkin of goin to 18's and will go probably 10 wider front and rear, and I wanna make sure I'd still be fine doin that and not mess stuff up. how wide of a wheel should I go? for fronts and rear? I'm thinkin 9 rear and 8 front. from what you guys posted I guess I'll be alright, thanks, I'd still like more opinions.
Old Jul 7, 2010 | 04:47 AM
hyperion_'s Avatar
It all depends on what offsets the wheels are. Read: https://www.s2ki.com/forums/index.php?showtopic=342793
You could probably go with 11-12" in the back if they were the correct offset but if the offset is wrong then a 6" wheel will stick out and rub.
Old Jul 7, 2010 | 12:12 PM
Former Sponsor
He mentioned on the stock AP1.
Old Jul 7, 2010 | 08:16 PM
TurboCongo's Avatar
I know some turbo S's are running 255/50 MT's... so 255 is definately an option!
I lowered on the 245/50's about a 1.5"s with no problem!
Old Jul 24, 2010 | 05:36 PM
Rudy-S2k's Avatar
Why wouldn't you run the 245/50/15 in the rear?
You all have the G-force sports I believe in that sizing with the 225/50/16 in front.
Old Jul 26, 2010 | 11:27 PM
Rudy-S2k's Avatar
Bump for my question.
