ap1 max tire width
Hugely depends on wheel offset.
Have a look at the first post here: https://www.s2ki.com/forums/index.php?showtopic=342793
I've got 235/45r17's in the rear now and 215/45r17 in the front, and I'm thinkin of goin to 18's and will go probably 10 wider front and rear, and I wanna make sure I'd still be fine doin that and not mess stuff up. how wide of a wheel should I go? for fronts and rear? I'm thinkin 9 rear and 8 front. from what you guys posted I guess I'll be alright, thanks, I'd still like more opinions.
It all depends on what offsets the wheels are. Read: https://www.s2ki.com/forums/index.php?showtopic=342793
You could probably go with 11-12" in the back if they were the correct offset but if the offset is wrong then a 6" wheel will stick out and rub.
Originally Posted by Jim@tirerack,Jul 6 2010, 12:38 PM
You can safely run 225/50R16 front and 245/45R16 rear. The problem is the only tire I have available would be the Fuzion ZRI that would have matching tires.
If I can help let me know.
You all have the G-force sports I believe in that sizing with the 225/50/16 in front.
