AP1 tire question for Jim
Old Dec 19, 2005 | 01:06 PM
RyanS2000's Avatar
Default AP1 tire question for Jim
Hi Jim,
I have a 2002 S2000 I bought back in March 05 with only 4100 miles.
Everything was original on the car of course because of the low mileage. It has the OEM Bridgestone Potenza S-02's. The rears are completely shot now at 15,800 miles, the belts are starting to show on the inside of the driver's rear tire. For handling/performance purposes I should stick with the S-02's until the fronts need replacing, correct? The fronts seem like they might have 50% left on them, but I'm not sure. Are there any rears that would be a good match with the S-02's up front? If not, I am considering going with a different tire once I need to replace all four. Are there any tires with comparable performance to the S-02 that are more economical? I realize that to have the same performance it will be soft compound and wear quickly, but maybe there is something of comparable performance with a better price?
Thanks in advance,
Ryan
Old Dec 19, 2005 | 01:51 PM
RyanS2000's Avatar
If anyone else would like to give their input as well, please feel free!
Old Dec 19, 2005 | 02:58 PM
xviper's Avatar
Most owners report a rear tire usage of 2 to 1 (compared to fronts). Just get another set of OEM SO2s for the rear and the next time you need tires, both ends should be worn out about the same time.
Old Dec 20, 2005 | 06:30 AM
RyanS2000's Avatar
That's what I was thinking of doing. When all 4 wear do you have any suggestions of a comparable tire to try in their place? I live in Florida so I drive the car year round, in the summer we get a decent bit of rain. The S02's were good enough for the rain, but I wouldn't want anything with worse wet traction.
Old Dec 20, 2005 | 08:27 AM
Jim@tirerack's Avatar
Former Sponsor
Take a look at the RE750 if you want longer wear. They offer much better wet traction, longer tread life and more comfort.
If I can help let me know.
Old Dec 20, 2005 | 10:52 AM
RyanS2000's Avatar
[QUOTE=Jim@tirerack,Dec 20 2005, 12:27 PM] Take a look at the RE750 if you want longer wear.
Old Dec 22, 2005 | 07:39 AM
JDR159's Avatar
Another tire you might want to consider is the Bridgestone S-03. These are the "next generation" from the S-02, and have a higher UTOG rating, and are considered better in the rain. I have these on the back and like how they handle the rain here in central NY.
If you're looking for alternative tires, Car & Driver has an article rating a number of performance tires. This article has graphs for each aspect of testing (wet/dry) for each tire. By using the graphs, you can decide what factors are most important to you, and adjust the outcome accordingly.
This is a good place to start to see a balanced overall look at tires that S2000 owners might be interested in.
98TypeR#21
May 13, 2009 04:49 AM
manymotors
Aug 20, 2007 06:21 PM
chris2002
Apr 10, 2007 02:01 AM
avs2k
Apr 19, 2003 08:43 PM
kumar75150
Jan 26, 2002 09:05 AM
