AP2v1 rims flush
Old Oct 29, 2011 | 02:09 PM
marios2000's Avatar
Default AP2v1 rims flush
Hey guys what size of spacers should I buy to make my stock AP2v1 rims flush. The mods I have are tein s techs springs and since I have these springs am I going to have to roll my fenders? Does my tire size make a difference because i have 235s in the front and 255's in the back. thanks
Old Oct 29, 2011 | 02:26 PM
hypforlife32's Avatar
235s up front is a large tire, are you looking for a good amount of camber? id say run a 10mm up front and a 15mm in the back, and yes you will need to roll your fenders. you can almost run stock camber in the rear with 15mm, maybe even stock camber.
Old Oct 29, 2011 | 02:42 PM
Froth.'s Avatar
I'd do 15mm all-around personally, That way you can use all bolt-on spacers and not worry about pressing studs out for longer ones etc etc... The size of the spacer and rolling fenders will usually depend on how low the car is but I can tell you right now with 235's up front I would have rolled the fronts a LONG time ago, it's just a matter of time before the tire catches and lips out one of the front fenders.
Generally speaking, Flush + Lower = Roll fenders. FYI, there is a thread dedicated to this exact topic:
-https://www.s2ki.com/s2000/topic/668408-the-quest-for-flushness-using-ap2-oem-wheels/
jsenclosure
Apr 20, 2014 04:46 PM
Eviljokersti
Jan 17, 2013 10:02 AM
s2kLi
Jan 8, 2012 08:50 PM
zbrewha863
Apr 10, 2009 05:50 PM
racecar fun
Aug 29, 2008 11:35 PM
