AP2V1 square setup
Old Oct 30, 2013 | 05:46 AM
t-o_double_d's Avatar
Default AP2V1 square setup
I have 2 sets of ap2v1's and decided to run all the rears for a square setup. I know they wont just slap on and work. I have read either bore out the hub or get spacers. My more direct question is does anyone have a spacer they recommend? This is what I found so far and I believe it should work.
http://www.evasivemotorsports.com/mm...=HR-DRS-SERIES
Any help would be appreciated... Also if anyone is looking for some AP2V1 front wheels let me know.
Old Oct 30, 2013 | 07:06 AM
1nate7's Avatar
If I had to choose, I would bore the wheels out. All 5mm spacers are pretty much going to be the same, most of the cost is the extended studs that are included. H&R is a quality piece should you go that route. I believe it is recommended, if not required, to replace the hubs as well when changing the studs.
Some people run 5mm spacers without extended studs although I wouldn't really recommend it, especially for track use.
Old Oct 30, 2013 | 07:34 AM
I should have also mentioned that I already have extended studs. Also these wheels are for city and highway driving... I have another set of wheels that are 17x8.5 that I run for autox and track
Old Oct 30, 2013 | 12:09 PM
s2000Junky's Avatar
5mm spacers are fine to run without extended studs, many do it without issue track/street, but that would be the limit. You want a minimum of 6 full turns out of the lug nut to get a proper hold.
JSR_AP2
Oct 3, 2013 03:11 PM
DesiS2k
Mar 22, 2011 05:05 AM
Castor
Jan 30, 2007 08:34 PM
sk2 01
May 4, 2006 06:12 PM
KeithD
May 24, 2004 09:19 AM
