7mm Wheel Spacers
Old Feb 6, 2011 | 06:06 PM
DesiS2k's Avatar
Default 7mm Wheel Spacers
So ive been searcing a lot regarding wheels spacers and their pronenlyness to make wheels go flying off. To me it sounds a bit drastic. The ones I have ordered are only 7mm for the rears to make my +50 to come out a bit more.
all in all, will this be okay? or are they compeletely unsafe?
Thanks in advance!
Old Feb 6, 2011 | 06:28 PM
FISH22's Avatar
I think 7mm is pushing it without extended studs. IMO, I wouldn't go over 3mm without new studs, but I've seen plenty of people say that 5mm is ok.
Old Feb 6, 2011 | 06:59 PM
Beezy.'s Avatar
I ran 5mm spacers on my old setup. Never had a problem, even took a long road trip to Texas and back to tenn, and many trips to atl, no problem. Is alittle scary cause there wasn't much stud but she held.
Old Feb 6, 2011 | 11:01 PM
LickyMYwalker's Avatar
i track on 5mm spacers and its fine. 7mm im not so sure...
Old Feb 7, 2011 | 05:59 AM
DesiS2k's Avatar
aghhh...you guys are scaring me
Old Feb 7, 2011 | 06:09 AM
award78's Avatar
Someone need to be the first.
But I wouldn't
Old Feb 7, 2011 | 07:17 AM
deepbluejh's Avatar
Would have been a good idea to ask this question before you ordered. As others have indicated, this probably isn't a safe setup. Given that it's a completely aesthetic upgrade, I'm going to file this one under "not worth it".
Old Feb 7, 2011 | 08:52 AM
1nate7's Avatar
You will lose almost 5 full turns of the lug nut. 5mm will probably be fine but it isn't recommended.
Old Feb 7, 2011 | 04:05 PM
PanteraKitty's Avatar
Most sanctioning bodies require a minimum of 3/8" thread engagement. Personally I want the thread engagement to be at least equal to the diameter of the stud. On our 12mm X 1.5 pitch studs, 3/8" would be 6 1/2+ complete revolutions of the nut. 12mm engagement would be 8 complete revolutions of the nut.
Here is a little clip of properly torqued nuts that did not have the proper thread engagement:
[media]http://www.youtube.com/watch?v=OQlxPZznrFo [/media]
Old Feb 7, 2011 | 04:11 PM
INSTALL LONGER STUDS!!!
