ASA Wheel
Old Apr 25, 2002 | 08:31 AM
  #21
Kwando's Avatar
Pictures are up.
https://www.s2ki.com/forums/showthread.php?...?threadid=58839
Old Apr 29, 2002 | 12:36 PM
  #22
raddray's Avatar
If you look for the wheels under the s2k list, it doesn't show up as an option anymore.
A new wheel does show up. Mille Miglia HT3 17x7 but it doesn't show a wider wheel for the back.
So anybody get this ASA wheel? Pictures?
Old Apr 30, 2002 | 07:45 AM
  #23
demonderrick's Avatar
I think after you lower the car, it will denfinitely rub the fender...
Old Apr 30, 2002 | 08:02 PM
  #24
shingles's Avatar
Yeah I haven't drive the car except really up and down the drive way and this street here to try and get things to settle after installing(thought was maybe jacking the car up cause the car to sit higher so I wanted it to settle). Well I suspect under heavier suspension loads, it could potentially rub.
These guys definately stick out at the current fitment.
Old May 1, 2002 | 08:16 AM
  #25
PLYRS 3's Avatar
[QUOTE]Originally posted by shingles
[B]Yeah I haven't drive the car except really up and down the drive way and this street here to try and get things to settle after installing(thought was maybe jacking the car up cause the car to sit higher so I wanted it to settle).
Old May 1, 2002 | 10:14 AM
  #26
reds2k1's Avatar
Aside from the offsets issue, the wheels look great! Kind of has the deep-dish look to it.
Old May 1, 2002 | 10:48 AM
  #27
shingles's Avatar
[QUOTE]Originally posted by TKG 26
[B]
shingles, any explanations from jim about the "bad" offsets ??????
jim, now that we have someone who has them on the car, can you please comment on offset/fitment since it doesn't seem to fit correctly as you've adevertised?
Old May 1, 2002 | 11:14 AM
  #28
PLYRS 3's Avatar
[B]Spoke with Jim this morning over the phone.
Old May 1, 2002 | 02:57 PM
  #29
shingles's Avatar
my 18" SSR GT1's have the same offsets and are also 8 and 9 wide - i have no problems either...
shing - not withstanding my aggressive aligment, they never rubbed before the alignment....and my car is lowered with kg/mm's....
And that's with 9" wide and 55mm offset?
As you can see from my pictures, mine as obviously sticking out... my original plan was to use soem kg/mm from Mingster, especially after reading that Tire Rack guarantees the fitment.
Old May 1, 2002 | 04:00 PM
  #30
socal28's Avatar
The only thing I can think of is that different manufactures have different ways of measuring offsets!
Sucks! I know!
The only way to really tell is actually having someone try on a set!
