Autocross Setup - Right Wheel/Rims
Old Jul 11, 2009 | 04:59 PM
S2KPC's Avatar
Default Autocross Setup - Right Wheel/Rims
Looking at setting up for autocross/solo II and think I want to run 245/40/17s all round.
From the sticky on wheel fitment guide, for 245 tires, the minimum offset is +63 for the front rim.
Does this mean that +65 would work, but +58 wouldn't. Or, is it the reverse.
Guess I'm confuse on how offset works.
Old Jul 12, 2009 | 12:16 AM
s2000_vtec_mike's Avatar
I belive it is reverse because in order to clear bigger calipers I was told i need lower offset.
Old Jul 12, 2009 | 12:48 AM
Fast Jack's Avatar
What size rim are we going to be using? Some people like non-staggered and some don't,I'd check it out before doing anything.Might not like it I've read that to take full advantage of the non-staggered set up,you have to the driving skills to induce over/understeer at will.Modding can be a can of worms,you do one thing and then you have to do another to compensate for it.
Old Jul 12, 2009 | 04:38 AM
ZDan's Avatar
+63 minimum means +63 would work, and +58 (which is LESS than 63, the MINIMUM) will likely rub.
Fitment for a big brake kit is a different question.
If you're setting up for autoX, the first question is what class you intend to run. If stock, you'll have to run stock wheel widths and offsets within ~5mm of stock.
Stock, you'd likely want to run 225/45 fronts and 255/40-17 rears.
(although some run 245/40 fronts and 275/40 rears which are way outside the recommended size window for stock 7" and 8.5" wheels!).
If not stock, 245/40-17s up front with 255/40-17 rears, or 255's all around, or maybe 275/40 rears.
Old Jul 12, 2009 | 05:43 AM
Fast Jack's Avatar
Talk to an AP2 guy about a good alignment setting.Save your $$ for tires And seat time Seriously, driving skills will make u faster than all the mods money can buy.Just enjoy your car
Old Jul 12, 2009 | 05:54 AM
S2KPC's Avatar
Also forgot to mention ... the alignment would be a bit different ... probably -2 camber front & rear. And, 1/8 to 1/4 toe on the rear.
Think this kind of throws the tables off.
Doing a little research, the rims should probably be 17x8.5 with an offset of +50.
Am I on the right track??
(Note: Class would be the new STR -- right now at least, don't think the rules care about offset ... just can't be more than 8.5 on the rim width.)
Old Jul 12, 2009 | 07:17 AM
ZDan's Avatar
I would want more offset for the fronts in order to run 255s or at least 245s.
Old Jul 12, 2009 | 10:31 AM
Mar48's Avatar
can we even fit 15s in the front?
Old Jul 12, 2009 | 11:53 AM
CKit's Avatar
Doing a little research, the rims should probably be 15x8.5 with an offset of +50.
For ST-R, probably would want 17s to have the most tire choices.
Old Jul 12, 2009 | 12:55 PM
S2KPC's Avatar
[QUOTE=Mar48,Jul 12 2009, 10:31 AM] can we even fit 15s in
