Biggest wheel size that will fit stock s2k
I've got a stock s2k that hasn't been lowered. I plan on getting some aftermarket rims, but won't go bigger than 18". Will my tires rub if I go with a 18 inch wheel? And what size tire is generally used for 18 and 17 inch wheels on an s2k for the front and back? If anyone has some pics they could post to give me an idea that'd be great also.
I know that you are a newbie and I have watched your recent posts. I think it is time that you started doing some due diligence on the site - there is a wealth of information to be found to answer virtually all of the questions which you are posting or will likely post in the future - as you can see from the two responses which you have received to date . Time to do some work on your own and become familiar with what info is available on the site. If you don't find an answer then, but only then, would it be appropriate to come back to the board for help. People will be more receptive if they have seen that you have first struggled a bit on your own. Good luck and enjoy your new ride - you will not regret its purchase.
