Black Five Spoke with Polished Lip...
I would kill for a set of Work S1's...
So I can't really afford the Work S1's or SSR SP1's. I know about the Rota D2's and forget all the hatred towards Rota...I would rock them but the weight scares me. Are there other affordable options out there that look similar but don't weight 4lbs more each per wheel?
If you are rocking the 18" Rota D2's, did it make a big difference in acceleration and handling?
Thanks
Thanks
S1s and SP1s are not that light.
now sure how much the rotas weight.
I'd expect the 3pc S1s to be about +23lbs in the rear, same for the professors.
Don't worry about the weight too much, not very noticeable.
I wouldnt worry about the weight on 18's... if you really do want to save the most weight than worry about the tire weight since they actually weigh alot more than the rim itself.
Toyo T1r comes to mind when it comes to weight savings for 18" tires.
