CALLING the alignment gurus
Hey all!
I need some help here.
This topic has been beat into the ground, and I have searched it many times too. I understand the two most common alignment suggestions are:
US spec alignment: less tire wear, more neutral handling.
UK spec alignment: poor tire wear, but aggressive handling.
Here is my delima... I am currently on ssr comp's in a 17x8 +48 and 17x9 +55 stagger with falkin azenis 225/255 stagger. My front fenders are completely stock and unmolested, and my rears are rolled fairly flush with my bumper tab STILL in the stock location. I am lowered on skunk2 springs on koni yellows.
I need someone with alignment knowledge to suggest some settings. The car is my daily so I don't want my alignment to be hell on my tires. BUT, it is also a weekend warrior that sees the mountains fairly often.
So, someone... someone with really good knowledge... please post up a suggestion of a good alignment. if possible, please post it in a manner that I can literally print it out and take it to the local shop that does all my tire work.
Thanks in advance.
Thanks in advance.
no one?
I was kinda hoping to get the car dialed in wed or thurs since I am leaving town to go see family in TN this weekend.
As mentioned before, I have searched... which is why I didn't want to post another alignment question.
BUT... i can't find any definitive specs that will still allow a reasonably even tread wear and good handling.
Camber
Front: 1.25 deg
Rear: 2 deg
Caster
Front: Maximum (close to 7 deg)
Toe
Front: None
Rear: 1/8in total
Camber will not really wear your tires out too much faster unless you really have a lot.
I would suggest more camber in front, but with a 225 there is a balance between braking and turning. If you go to the track or drive the mountains/canyons REALLY hard, then you you should go with 1.75 front camber and 2.25 rear camber.
Front: 1.25 deg
Rear: 2 deg
Caster
Toe
Front: None
Rear: 1/8in total
Thanks for the advice, guys!
I will just go with the euro alignment specs. (basically exactly what carerra posted also... just .25 less camber in the front.).
judging from your posted and the few pm's that I have received, the euro alignment is not going to destroy my tires and I will be very pleased with the handling.
Thanks again!
Thanks again!
chairmnofthboard
30
Dec 15, 2016 07:39 AM
superjimbo
Dec 14, 2005 04:13 PM
