Camber help
Old May 28, 2014 | 08:08 PM
sunk318's Avatar
Default Camber help
I bought 18" CE28s not too long ago, and noticed that I rub when I drive spiritedly. I never rub on daily driving though. And this is with stock suspension setup.
This weekend, I will be installing Koni with Eibach springs to lower my car 1" all around. I am planning on getting negative camber, but was wondering what I should set the neg degrees at. I wouldn't mind it rubbing on an aggressive turn, but don't want it to rub on daily driving.
Here are the specs for the wheels:
Specs: front 18x7.5 43 offset. 225/40/18. Rear 18x9.5 40 offset 255/35/18
My rears fenders are rolled.
Let me know what you guys think.
Thanks!
Old May 28, 2014 | 08:16 PM
Manga_Spawn's Avatar
Site Moderator
Roll your front fenders ASAP. They are in more danger and will rub more on daily driving than in a track situation. But either way once it rubs through the liner it will grab the fender and damage it and likely damage your tire. As for camber -2 front -2.5 to -3 for the rear.
Old May 28, 2014 | 08:22 PM
JamesFM's Avatar
Definitely roll the fronts. 18x9.5+40 with a 255 in the rear is probably going to need a little more than -3 degrees of camber. I also have a 1" drop, and my specs are 17x9+38 with a 245 in the rear and I had to run -3.5 degrees in the back.
Old Jun 1, 2014 | 10:05 PM
sunk318's Avatar
Thanks for the advice. I lowered my car today (thanks to spets aka crazy russian), and it rubs on hard turns or very few rough spots on the freeway.
I wish I rolled the fronts when I did rears, but now that I wrapped my car, I won't be able to roll them anymore. It will simply cost too much to rewrap those fenders.
The rubbing isn't as bad as I thought. I am thinking if I do -2.5 for the front and -3.5 for the rear, I should be satisfied.
I will report in when I get alignment.
Old Jun 2, 2014 | 09:54 AM
s2000Junky's Avatar
Have fun flipping your tires every 4k miles.
Old Jun 2, 2014 | 10:15 AM
Site Moderator
It is going to cost even more when your wheel damages your fender. If spets helped you it means you are in the Seattle area so I can roll your fronts. Rewrapping the fenders will be much cheaper than fixing damaged fenders and rewrapping.
20civic07
Apr 12, 2013 01:45 PM
tai-tai
Apr 22, 2010 03:34 PM
dezignpro04
Sep 3, 2008 07:52 AM
dwedge
Dec 27, 2007 10:36 AM
Y2Ksil/red
Mar 3, 2007 10:04 AM
