Camber Problem!
Old Dec 27, 2006 | 07:29 AM
michins2k's Avatar
Default Camber Problem!
Hi. I have a problem with my s2k...I bought the car lowered on Tein H.Tech...and I relealized couple days ago that my passenger side has real bad negative camber.
I know the s2k has adj. camber in the front and want to know if getting an alignment would fix the problem. It looks like this kind of...
Old Dec 27, 2006 | 08:32 AM
silentdancer's Avatar
yes getting an allignment would help.
Old Dec 27, 2006 | 09:13 AM
michins2k's Avatar
Oh...thank you. I was scared something bad happened.
Old Jan 1, 2007 | 09:14 PM
05TurboS2k's Avatar
help...but not solve the prob, i have 2 bent lower A arms so take it from me. The problem is probably deeper then alignment. You need to have the bushings looked at....and check if somethings bent, if its THAT easy to spot....it means you likely have a problem, not to say it can't be adjusted to be corrected but...what about when it comes outa adjustment again and ur outa adjustment room....thats my situation. Have it checked out by someone who really knows suspension.
Dreaming_S2k
Nov 9, 2015 04:51 PM
boyguan
Jun 2, 2010 07:44 PM
bigwhite
Jul 19, 2009 09:16 PM
APOSTLE SBG
Feb 19, 2009 12:45 PM
elude
Oct 19, 2004 08:56 AM
