Correct offset help???
Old Jan 4, 2003 | 02:37 PM
darkknight1999's Avatar
Default Correct offset help???
Hi all,
I am looking into a set of new rims and I found and would like to know if they will if properly. By properly I mean: no rubbing, no tire sticking outside the wheel well, the ability to lower the car about one inch.
I was looking at a 18x8 for the front and 18x9 in the rear, what would the proper offset be? I was think about +54 in the front and +63 in the rear???
But I want to be sure before I call to order them.
Also what are the best aftermarket tires for the car other than the stock oem S02's, or can I get those tires in the above size?
Thanks in advance!!
-John
Old Jan 4, 2003 | 03:30 PM
socal28's Avatar
Those offsets are about what I would recommend!
I'm not sure about what's the next best tires than the SO-2's. I'm running SO-3's, they are nice, but they are pretty heavy tires!
The sizes should 225/40 up front and 255/35 or 265/35 rear.
Good luck!
Old Jan 4, 2003 | 05:28 PM
xviper's Avatar
[QUOTE]Originally posted by darkknight1999
[B]Hi all,
Old Jan 4, 2003 | 05:33 PM
Tireguy's Avatar
My 18" set up is as follows 18 x 8 55 offset 225/40-18 (fronts) 18 x 9 65 offset 265/35-18 (rears). Lowered one inch on Eibach springs and no rubbing.
Old Jan 4, 2003 | 06:18 PM
Thanks for all the help guys!!
Old Jan 5, 2003 | 02:17 PM
What is the S2K bolt pattern?
Old Jan 5, 2003 | 08:47 PM
Tireguy's Avatar
5-114.3mm or 5-4.5"
Old Jan 6, 2003 | 05:02 AM
Thanks!!
minboost
Sep 19, 2010 08:14 PM
Suzuka_05
May 3, 2006 12:20 PM
batikan
Oct 8, 2005 08:49 PM
S2KEvolution
Jan 13, 2004 01:20 PM
LIL RAJA
Mar 12, 2003 12:34 PM
